MRF477
cb4ever104
MRF477
Post by cb4ever104 » 30 May 2019, 11:58
Is this 477 real ?
https://www.ebay.es/itm/202690097604
Doesn't look right to me . Saying that I'm probably wrong :)
14CS06
Re: MRF477
Post by 14CS06 » 30 May 2019, 12:15
Hello Paul
MRF477 9224
seems to be the same
cb4ever104
Re: MRF477
Post by cb4ever104 » 30 May 2019, 13:02
I don't like it Claude . Aren't there normally 2 little indentations on the main body ? Also , the letters don't look right to me either .
4a0026aleks
Call Sign: 4a0026
Re: MRF477
Post by 4a0026aleks » 30 May 2019, 14:49
Hello dears! when I had President Jackson I accidentally burned the mrf477 transistor. I successfully replaced кт920 (Russia)
4a0026aleks
Call Sign: 4a0026
Re: MRF477
Post by 4a0026aleks » 30 May 2019, 14:50
I had to Unscrew the black radiator and drill a hole for the nut inside .output power has not changed
4a0026aleks
Call Sign: 4a0026
Re: MRF477
Post by 4a0026aleks » 30 May 2019, 14:52
in any case, fake transistors made in Russia does not happen....
Otter
Call Sign: 26TM439
Re: MRF477
Post by Otter » 30 May 2019, 17:31
It looks good to me.
cb4ever104
Re: MRF477
Post by cb4ever104 » 30 May 2019, 18:16
Otter wrote:
30 May 2019, 17:31
Fair enough Tim . :thumbup:
Mitch
Re: MRF477
Post by Mitch » 31 May 2019, 08:46
cb4ever104 wrote:
30 May 2019, 11:58
Is this 477 real ?
Don't look right to me . Saying that I'm probably wrong :)
Have the pins been tinned? Back in the day we called these 'gold leggers' because the pins were gold coloured. They were expensive then too.
The perfect face for radio.
Otter
Call Sign: 26TM439
Re: MRF477
Post by Otter » 31 May 2019, 09:08
The 1990s ones didn't have gold legs. They did in the '80s.
dt307
Call Sign: 163dt307
Re: MRF477
Post by dt307 » 31 May 2019, 09:35
finished this 1 off last night with a sd1446 but a mrf455 also work the same and cheaper and will last longer than a 477 less than £30 new from a main uk dealer via rm italy.
just a thought for you sammy, i know you can make a pcb up to hold the 455/1446 but i fitted a nos driver and used final and this way the bill to the customer fitted is going to be £25.
2x560pf caps removed,bias diode removed,new 4001 bias doide fitted so not hard to do
163dt307-chris
― Albert Einstein
dt307
Call Sign: 163dt307
Re: MRF477
Post by dt307 » 31 May 2019, 09:42
side note incase any1 tries it.
you must ground 1 of the emitter tabs via 1 of the screws.
the mod is rogerbirds.....( lincoln guru) detials on the cbtricks website under hr2510
163dt307-chris
― Albert Einstein
Otter
Call Sign: 26TM439
Re: MRF477
Post by Otter » 31 May 2019, 13:03
All of these were bought before Chinese fakes were even thought of.
The modern fakes on eBay have the word "ON" in a circle. On semiconductors never made MRF477 or MRF497.
cb4ever104
Re: MRF477
Post by cb4ever104 » 31 May 2019, 13:45
Otter wrote:
31 May 2019, 13:03
It's strange how the sight of a few transistors can get the juices flowing :)
Techquest
Call Sign: 29VLF125
Re: MRF477
Post by Techquest » 31 May 2019, 14:01
Any so called MRF477 with a date code later than 95 is fake they stopped making them in 95.
real 477s the plastic is black not slate or gray the one in the pic is the real deal to look for anything that has any other logo than the Motorola circled M is not.
Re ON Semi as Otter said they never made 477s or 455s in fact they dont make any RF transistors for the HF bands.
Techquest AKA Jedi
Av101 Astro Plane Old Imax n Loads of Radios
Mmmmmmmmmmm ADAMS n other Presidents
