Could some kind Nato 2000 owner have a look at the wire located on the expansion/beep board [Marked in red square in attached image] and trace it back to where it goes please.
Wire off in Nato 2000 help please
- 163TM847
- 163TM847
Re: Wire off in Nato 2000 help please
I guess no one owns a Nato 2000 on here.
- cb4ever104
I don't , or a would have replied . I'm sure someone must have one ...
- Buick Mackane
- Moderator
Can you not trace it on the schematic ?
- 163TM847
Done now, It was the beep audio output wire, But beep was feed backing through speaker, Q603 was blown so there was no delay to the relay, Which would explain why the wire was cut off.
Schematic never seems to include the Expansion/Beep board as it was only the Nato 2000 that had it.
- Call Sign: M3CBY
I know you have sussed it but in case you need it in the future the Nato 2000 schematic and one for the Sub PCB can be found here https://1drv.ms/f/s!AiFwsALeEFbbrNUbPH4JU8Ok8GEBSg
Glad you got it sorted Nick. I was all set to take mine off the shelf and take the cases off for you over the weekend. I can relax again now as I'm not feeling too good at all and I wasn't looking forward to a trip up into the loft
I've got 2 Nato 2k's (a standard one and my copper-coloured one) so if you should need anything picture-wise in the future, then let me know mate.
- Call Sign: 26TM672
A bit late to the party but here, radio is packed away but I had a couple of internal photos from a few months back.
Simon
Simon
Nato 2000
Lafayette AFS-805 MKII
Ham International Concorde 2
Major M360
Superstar 360FM
Petrusse Pacific 160
President Lincoln MK1
Alinco DR135UK
Kenwood TS-480HX
Yaesu FT-2000
Major M360
Superstar 360FM
Alinco DR135UK
Kenwood TS-480HX
Yaesu FT-2000
