Does anybody have any experience of this wonderful amp?
Seems to be working, up to a point. There is an issue with it staying in TX in high power positions. It's almost like RF feedback, but it does it in to dummy load. Not tried it into an antenna, it would probably fry mine.
I did think about parasitic oscillations, but thought it best to see if anybody else has experience, before I start poking around inside it, for obvious reasons
KLV1000 fault
- dt307
- Call Sign: 163dt307
Re: KLV1000 fault
i would send it to some 1 that knows what they doing or some 1 brave . the schematic for the rf sence is a bit ott and lots of scope for rf to get in. i personaly would convert it to ptt switching. i dont want to tell you what you should be checking as you will need to check them in fault conditions ie amp on and running,could be just a cable came loose from its mountings and touching a place where its not ment to or some thing else bad earth ect .there is the scope to KILL you messing about inside this amp so i cant go into details m8 sorry.and i aint a fan of messing with hv. start with the simple things earth the amp and having a dummy load too close to the unit will also do this and a lot of rf will come out of the dummy load .if your antenna swr is ok just try it on your antenna m8
163dt307-chris
― Albert Einstein
― Albert Einstein
Re: KLV1000 fault
Also . Try using a few different patch cords .
S.
S.
