MK1 President Lincoln issue
Just got the Lincoln set up after a while. All is intact but like to listen it through the extension speaker but can't find the adaptor to plug into the cell block at the back of it. I know truck king used to sell them. Just wondered if anyone had any link to getting hold of one. Can only describe it as being a 3.5mm jack plug with the other end being 2 pins that plug into the Lincoln. Any help would be appreciated.
gholdq on youtube.com
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
- cb4ever104
Re: MK1 President Lincoln issue
The standard "white" 2 pin connector is only used with the internal speaker Gareth . To hook up an external speaker you need the "accessory" plug , or a bespoke version with just the 2 wires for the external , with no PA , or CW wires . I've just done one for a member on here , but I'm away from home now . Do a forum search on "Molex" and you'll find info on them .
I have the accessory plug but can't find it anywhere. Does anyone know of a supplier to obtain another one.
I know the simple thing would be to modify the back panel to accommodate a jack plug socket but want to avoid that if possible.
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
- cb4ever104
I can make you one , but won't be able to do it till Easter. Think there's a guy in the States doing them too. Search Ebay for HR2510.
Sammy
Sammy
- Otter
- Call Sign: 26TM439
- 14CS06
- Call Sign: 26SF333
Sammy just done one for me at a really reasonable price,makes it so much easier now to have extension speaker on my 2830.The ones of the guy in the States r much more in cost than the one Paul,Cb4ever104 did for me.Again thanks Paul
- cb4ever104
No problem Mark. Glad to help you out
If you could make a couple for me Sammy that would be great.
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
- cb4ever104
Hi Gareth.
I've still got you down on my list for Easter. I did Mark's one last month when I was home.
S.
