President JFK ASC module wiring
- 13EL121
- Call Sign: 13DA121
Hi friends, HNY!
Just got a JFK in where the ASC is not working. Preowner has activated Roger Beep at the Power adjustment. If Roger Beep is enabled, squelch does not work. So i am looking for schematic for the Uniden PA-338AC JFK with ASC.
Thanks and 73s,
Ralf
Thanks and 73s,
Ralf
- 14CS06
Re: President JFK ASC module wiring
Hello Ralf
Please look at these pics for JFK and JFK ASC
Mods for make independent Beep and ASC
Sorry in french
Schematic without ASC
Claude
Sorry in french
Claude
- 13EL121
Excellent Claude! Thank you very much. Will have a look at it.
- 13EL121
The wire colours seem to be different here. What a mess...
ASC wiring here:
Orange and yellow are not used in mine. Brown and black are grounded together to volume switch. Green goes to the pull switch. Red goes to 8v, blue to a resistor to PCB.
ASC wiring here:
- 14CS06
- 13EL121
Many thanks Claude! The wireing looks good so far. A picture from the soldering side would be great. I only see one from the JFK Classic without ASC. In mine there are a red and orange wire soldered together to one solder point.
- 14CS06
- 13EL121
Perfect Claude!
But it looks like mine. Can not see any difference in the section where both cables are soldered together. Hmmm...so i think the magic is the pull switch.
- 13EL121
Fixed...i removed the ASC module as i did not found the fault. Resoldered the tracks and squelch wire. Finally i removed the ASC Stickers and added a 1000uf capacitor for better voltage filtering. Now it is a JFK without ASC and working fine. Roger Beep and Squelch now working as it should. Thanks for your help my friend Claude.
- Crusader
Hi guys, i have a ASC JFK here & the blue wired from it with the resistor has come loose & i need to know where it fixes to so that i can resolder it back in to position.
I can see by the pictures on here it attaches somewhere near the front end of the pcb near the oblong black 455khz ceramic filter, but i cannot see exactly where it attaches.
- 13EL121
Hope this helps...
- 13EL121
Soldered on the top end of the resistor.
- Crusader
Hi,sorry for the delay in me replying & thank you for the pictures, yes i realised the blue wire attached to the resistor, i just wanted to know where the resistor soldered to? by the looks of it to the resistor next to D5.
Best 73, Shaun
- 14CS06
Hello
here
Claude
here
Claude
- Crusader
