President JFK ASC module wiring
13EL121
Call Sign: 13DA121
Post by 13EL121 » 04 Jan 2019, 06:24
Hi friends, HNY!
Just got a JFK in where the ASC is not working. Preowner has activated Roger Beep at the Power adjustment. If Roger Beep is enabled, squelch does not work. So i am looking for schematic for the Uniden PA-338AC JFK with ASC.
Thanks and 73s,
Ralf
14CS06
Re: President JFK ASC module wiring
Post by 14CS06 » 04 Jan 2019, 21:25
Hello Ralf
Please look at these pics for JFK and JFK ASC
Mods for make independent Beep and ASC
Sorry in french
Schematic without ASC
13EL121
Call Sign: 13DA121
Post by 13EL121 » 05 Jan 2019, 08:57
:thumbup: Excellent Claude! Thank you very much. Will have a look at it.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 05 Jan 2019, 10:15
The wire colours seem to be different here. What a mess...
ASC wiring here:
Orange and yellow are not used in mine. Brown and black are grounded together to volume switch. Green goes to the pull switch. Red goes to 8v, blue to a resistor to PCB.
14CS06
Post by 14CS06 » 05 Jan 2019, 10:40
Hello Ralf
Other pics
13EL121
Call Sign: 13DA121
Post by 13EL121 » 05 Jan 2019, 12:11
Many thanks Claude! The wireing looks good so far. A picture from the soldering side would be great. I only see one from the JFK Classic without ASC. In mine there are a red and orange wire soldered together to one solder point.
14CS06
Post by 14CS06 » 05 Jan 2019, 14:40
Hello Ralf
Is this ?
From
http://spectrum26.pagesperso-orange.fr/
13EL121
Call Sign: 13DA121
Post by 13EL121 » 05 Jan 2019, 16:32
Perfect Claude! :thumbup:
But it looks like mine. Can not see any difference in the section where both cables are soldered together. Hmmm...so i think the magic is the pull switch.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 05 Jan 2019, 19:52
Fixed...i removed the ASC module as i did not found the fault. Resoldered the tracks and squelch wire. Finally i removed the ASC Stickers and added a 1000uf capacitor for better voltage filtering. Now it is a JFK without ASC and working fine. Roger Beep and Squelch now working as it should. Thanks for your help my friend Claude. :thumbup: :thumbup:
Crusader
Post by Crusader » 19 May 2019, 19:50
Hi guys, i have a ASC JFK here & the blue wired from it with the resistor has come loose & i need to know where it fixes to so that i can resolder it back in to position.
I can see by the pictures on here it attaches somewhere near the front end of the pcb near the oblong black 455khz ceramic filter, but i cannot see exactly where it attaches.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 21 May 2019, 16:16
Hope this helps...
13EL121
Call Sign: 13DA121
Post by 13EL121 » 21 May 2019, 16:19
Soldered on the top end of the resistor.
Crusader
Post by Crusader » 09 Jun 2019, 01:45
13EL121 wrote:
21 May 2019, 16:19
Hi,sorry for the delay in me replying & thank you for the pictures, yes i realised the blue wire attached to the resistor, i just wanted to know where the resistor soldered to? by the looks of it to the resistor next to D5.
Best 73, Shaun :thumbup:
14CS06
Post by 14CS06 » 09 Jun 2019, 07:59
Hello
here
Crusader
Post by Crusader » 09 Jun 2019, 22:07
14CS06 wrote:
09 Jun 2019, 07:59
Hello
here
Fantastic Claude, as i suspected :)
Many thanks Guys :thumbup:
