JFK
superstar
JFK
Post by superstar »
is it possible to drop these down onto the UK 40 on hi band to make them more usable, they’re lovely sets, just want to get a bit more use from them.
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
cb4ever104
Re: JFK
Post by cb4ever104 »
I think you'll need to use a dedicated module for the uPD2816 . By the looks of things Mr Maurer has one .
Avenger
Call Sign: 163TM122
Re: JFK
Post by Avenger »
You can give high band the UK offset to get channels 1-26 on frequency if that's what you're after as my black face JFK and superstar 120fm's been done. Not sure about a full 40 Eprom or otherwise though?
163TM122 - ROB
wa10
Re: JFK
Post by wa10 »
what avenger said,
my jfk's are dropped for uk fm, you just need a small trimmer cap on the high band crystal.
W8JI
superstar
Re: JFK
Post by superstar »
ah ok chaps,thanks for the response, the trimmer thing will do, not bothered about the full uk, cool :)
Cb handle
The Collector
Re: JFK
Post by The Collector »
No one uses channels 27 and above as they all just seem to use ch19 nowadays.
I'm surprised someone hasn't come out with a new, 1 channel ukfm radio ;)
