JFK
- superstar
JFK
is it possible to drop these down onto the UK 40 on hi band to make them more usable, they’re lovely sets, just want to get a bit more use from them.
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- cb4ever104
Re: JFK
I think you'll need to use a dedicated module for the uPD2816 . By the looks of things Mr Maurer has one .
Sammy
Sammy
- Avenger
- Call Sign: 163TM122
Re: JFK
You can give high band the UK offset to get channels 1-26 on frequency if that's what you're after as my black face JFK and superstar 120fm's been done. Not sure about a full 40 Eprom or otherwise though?
163TM122 - ROB
Re: JFK
what avenger said,
my jfk's are dropped for uk fm, you just need a small trimmer cap on the high band crystal.
W8JI
- superstar
Re: JFK
ah ok chaps,thanks for the response, the trimmer thing will do, not bothered about the full uk, cool
Cb handle
Cb handle
Re: JFK
No one uses channels 27 and above as they all just seem to use ch19 nowadays.
I'm surprised someone hasn't come out with a new, 1 channel ukfm radio
