Quick question, chassis so239 grounding loose
original45
Call Sign: 45
Post by original45 »
Could a loose so 239 on to a radio chassis cause a rf power out fluctuation or drop. And secondly would or could this make audio sound like it was off frequency when transmitting on ssb .
Thank you.
The Collector
Re: Quick question, chassis so239 grounding loose
Post by The Collector »
I can understand it possibly losing power if the antenna connection is loose or moving around, but I wouldn't have thought it would've made it change frequency... unless it's naturally "drifting" whilst warming up.
I'm not up on SSB/AM radios though, so I'll step aside and let someone more qualified give their opinion just in case, as I'm probably wrong ;)
satelitesid
Post by satelitesid »
I would think that if the antenna socket is loose, there is a risk of RF feedback, which can sound like the radio is off frequency.
original45
Call Sign: 45
Thank you ,I assumed fluctuation of rf power possible but really was unsure of the effect in frequency drift.
Makes sense I guess.
Thank you both.
