Galaxy Saturn Signal meter not working
- slamjam
- Call Sign: 26DT871
Any ideas on this one - Galaxy Saturn ept360014b incoming signal meter not working. I can see voltage at the meter (multimater across terminals) when a radio in the shack goes to TX and there is a reading if I attatch an "antenna" (piece of wire to the meter terminal) so I at least know the moving coil is working but nothing normally. Any help appreciated
26DT871 - Ipswich UK
Re: Galaxy Saturn Signal meter not working
Switch s507 need to be checked (s--swr-cal), Diode D12.
- slamjam
d12 checks ok on a meter - will check the switch later when I get in the shack. Looks like someone has been there before me does anyone know how the meters should be wired?
Like on the schematic.
- slamjam
I've checked the switch and followed the circuit back to d12 which is all correct. I have also checked the voltages on the transistors tr13 and tr14 which check out to the correct voltages as per manaul - Also have checked both VR's - Any other ideas? Thanks so far Chris
Is SWR cal and reading working?
