AT-5555 service menu alignment howto
mw0uzo
Call Sign: mw0uzo
Post by mw0uzo »
AT-5555 service menu alignment procedure
Worked this out trying to sort my radio out. It got pretty complicated as I tried to work out what all the settings did and tried to get a feel of the filters etc. Went off in slightly the wrong direction to start with and ended up with weak opposite sideband rejection due being a little bit too far from the edge of the filter. Luckily, a post elsewhere on here put me back on track with a much simpler procedure and then I was able to get it working properly.
http://mw0uzo.co.uk/index.php/repairs/2 ... -procedure
Comments and improvements welcome.
listner132
Re: AT-5555 service menu alignment howto
Post by listner132 »
Yes bro this has been discussed to death on here over the years.U seem to have went to the next level tho... Glad u sorted it now tho. And this should help others.
