Hi guys,
my Lincoln 1 has a strange problem with squelch.
When radio is on and tune it on squelch, it stays in squelch even if you turn the knob back.
Only thing to put it "out of squelch" is to switch radio off and on again.
Adjusting VR102 does not solve this issue.
Anybody an idea? Leaking capacitors maybe?
Thanks! Ton
President Lincoln 1 Squelch problem
- KlondikeMike
- Call Sign: 9WR2000
Re: President Lincoln 1 Squelch problem
I am presently working on a Lincoln v1 right now. It has a few problems including a similar odd behavior with the squelch as well. First step, replace ALL electrolytics and then start troubleshooting. I'm half way through and when I get them all replaced I'll post my results.
- 1968neil
I have some notes from back in the day for the same fault, Can remember the fault was intermittent on mine so as Mike says maybe electrolytics drying up ? There are two to check in my list, either way id replace them anyway :
Regards
Neil
Q109
D115
C37
C33
TP = Pin 8 IC101
Regards
Neil
Q109
D115
C37
C33
TP = Pin 8 IC101
Thank you guys for a quick response.
I will start to recap the whole transceiver, parts are ordered today.
Will post the result as soon as i finished the job.
Best 73 from the Netherlands!
Ton
Ton
Replaced all caps on main board and Lincoln is perfectly
back in business!
back in business!
- 1968neil
Thanks for the update
Enjoy .....
Enjoy .....
So... which cap was responsible for bad sq?
