Anytone at 5555 no rcv noise on ssb.
Rob ptt
Call Sign: m0ptt
Post by Rob ptt » 04 Nov 2018, 20:42
Hi all,,been a while since i visited this forum but here goes,,i have purchased a Anytone AT-5555 which has a fault,there is no sound atall coming from the speaker in ssb mode even if the squelch knob is turned all the way in both directions but is fine on fm and am,is there a known problem with these radios? is it something i am doing wrong or is there a fix for this fault,,any help apreciated.
Cheers Rob.
Rob ptt
Call Sign: m0ptt
Re: Anytone at 5555 no rcv noise on ssb.
Post by Rob ptt » 05 Nov 2018, 11:55
Anyone help?
Call Sign: n0call
Post by ch25 » 05 Nov 2018, 15:01
Switch to USB and check if 8V is present on junction of C20 and R128.
astradyne
Post by astradyne » 07 Nov 2018, 17:02
Also check in the radio's menu settings, someone may have had a dabble and made a mess of things. Or you could try the factory reset option to see if that solves the issue.
listner132
Post by listner132 » 07 Nov 2018, 18:51
Check the simle thing first lik ASQ turned on...auto squelch
