President Lincoln MK1 2SC1674 replacement?
- Vapor
- Call Sign: dipstick
Hi to all and I hope some one in the know can help me with the replacement of a part in my president Lincoln mk1
From what I have read this part going bad can cause squelch chatter, the part I want to replace is 2SC1674 I can find the parts but there is a problem in which 2SC1674 to get as the replacement part? I don't want to do any mods to different parts as I have seen this some times causes more problems. all I want to do is replace the original part.
2SC1674 M 40-80
2SC1674 L 60-120
2SC1674 K 90-180
Does anyone know the correct value for the Lincoln MK1 please? will I need a M L or K part 2SC1674
thanks in advance.
2SC1674 M 40-80
2SC1674 L 60-120
2SC1674 K 90-180
thanks in advance.
CB dipstick
73's and Good DX people!
Re: President Lincoln MK1 2SC1674 replacement?
First from the drawer. No need to go deeper.
- Vapor
Why do they make 3 versions if it doesn't matter?
CB dipstick
Put the same version you had.
Difference is in β, but in SQ circuit does not really matter.
Point me where this TR is located exactly? How do you know that it is defective?
- Vapor
its Q101 located next to L101 when it goes bad it causes SQ chatter, only what I have read and my Lincoln does suffer with this, I have read you can change to a 2SC1999 but again some say it works some say it doesn't, so I thought I would replace with an original 2SC1674 but before I remove it I would like to purchase new one.
CB dipstick
Q101 is a RF amp. When it's go bad, your receiver is deaf. I don't think, that you need to replace it. It have nothing to do with SQ circuit which is based on NJM2902 opamp.
Does SQ chatter on dummy load or only on antenna? Does it chatter in autoSQ position, or when you set it manually too?
- Vapor
it chatters in auto SQ position and manual position.
this is what I read from internet
http://www.normsweb.com/tektips/lincoln.shtml
CB dipstick
On antenna, dummload, without antenna?
On antenna it is pretty common, that any signal over threshold will open SQ. That is why I never use it except FM sometimes.
- Vapor
on the antenna, low signals chatter in and out of SQ
to the point that you either have the SQ off and hear them, or if you have it set to just on the back ground noise, it chatters in and out and even low signals do the same
CB dipstick
- Vapor
let me describe it better, back ground noise s3 set SQ just above and this is on FM. if I get a signal of S5 it will chatter in and out, back off SQ and back ground noise floor will chatter in and out. so S3 to S5 can't open SQ with out chatter
CB dipstick
- Vapor
it never used to be like this, set SQ so a signal of S5 would lift SQ and I would get a clean signal in, but now it will chatter the SQ
CB dipstick
1. That is normal behaviour of SQ circuit.
2. Lincoln have wrong designed FM demodulator. That can be easily fixed.
Remove 10k resistor as marked on the pic. Take 5.6k and place as marked on another image. Voila. Difference in FM will be huge.
Also it is good to replace C412 from 47nF to 10nF - Opens deemephasis, better and louder FM reception.
- Vapor
so you remove the 10k resistor and don't replace it, then place a 5k to 6k resistor and place it in the place highlighted in pic 2
that looks easy enough, thanks
think that's a 5.6k resistor, what W value should it be? 1w 2w 1/4w 1/2w
CB dipstick
5.6 kΩ Small one. Wattage is not important here.
You can use even 1kΩ, in that case low signals will pass better.
After, check and realign L115 for maximum signal. Plastic screwdriver! Just find on the air fair low FM station and tune L115 for maximum signal. Simple as that.
C401 is located on vertical PCB next to that resistor you will be removing. In case you want to replace it too.
Also it is good to replace C61 from 560pF to 47pF, TX audio will gain high tones, become less muddy.
- Vapor
Thanks very much, will give it a go.
CB dipstick
