Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
Phuture wrote: ↑21 Dec 2018, 19:09
The amp settings provide a slightly higher voltage, but only by about 0.2V and 0.6V respectively.
If that's 0.9V then that's not right . The transistor should just switch on with a little base current on SSB . If you're doing it using voltage then I usually disconnect one transistor at a time and set them individually . That way you'll also locate any bias issues , if you have them .
30TM060 Paul aka "Sammy". (108) PY60 Old Paisley DX Group (RIP Rab Markie)
