President lincoln mk1 tx audio coming through speaker
tony2803
Call Sign: 163TM2803
Post by tony2803 »
Got a slight problem with my mk1 lincoln.
When transmitting on am.fm.ssb i get feedback coming through the speaker. The radio is putting out 10 watts am.fm and 21 watts ssb.
Does anyone have a solution to resolve this problem.
Thanks in advance.
Re: President lincoln mk1 tx audio coming through speaker
Post by ch25 »
astradyne
Moderator
Moderator
Post by astradyne »
The first run of the 2830's and Lincoln's all had this issue. Not sure if it was an intentional function or a manufacturing/design issue, but by the time the Philippines made radio's came out the problem of TX audio coming through the speaker had been resolved.
163TM847
Post by 163TM847 »
I have done the 10k resistor and 1n4148 diode in series to pin 6 of the audio amp many times and it works fine.
tony2803
Post by tony2803 »
Thanks for all the replies. Waiting for parts to arrive will post results.
tony2803
Post by tony2803 »
Just finished mod 3. Tested and it works perfectly.
Thanks all for imfo.
