Need help again
- Call Sign: 108SD121
Need help again
Hi guys I need to tighten the antenna socket but don't have the right key. Can someone please tell me what the key is called it's a BNC antenna socket I need to tighten.
Re: Need help again
It's the nut with the two slots opposite each other.
- GusWroclaw
- Call Sign: 161TM313
Re: Need help again
Something like this? https://www.amazon.com/BNC-Tool-Connect ... B00MEW0SCM
161-TM-313 - Midland Alan 42
- DX-Digger
- Call Sign: TM205
Re: Need help again
Can't get into it with pliers it's on my Albrecht hand held but thanks all the same.
- Call Sign: 26AT239
Re: Need help again
If you can post a picture of the part you need to tighten down we might be better armed to advise you of the tool you need to find.
- DX-Digger
- Call Sign: TM205
Re: Need help again
https://www.amazon.com/Stanley-84-096-5 ... 0001IW50Y/
These are what i was referring to long nose/needle nose pliers.
Re: Need help again
Not sure if it'll help, but you can sometimes put a small flat screwdriver onto a tightening ring/nut and tap it round with say a small hammer to tighten it providing the tip of the s rewdriver can sit in a notch or similar. You can then tighten it a bit at a time even if you can only access a few millimetres.
If this isn't what you're on about, then I'll shut up now
- GusWroclaw
Re: Need help again
ian please check my message above. It was in the moderation queue and now it appeared above the other replies. I think that's the tool you are asking for.
Re: Need help again
Thanks guys much appreciated think I'll have to take a photo of the nut and post it here later it's for the antenna socket nut on the top of my hand held can't get into tighten it because the case is in the way .
Re: Need help again
The Collector ur right in what I'm trying I've tried what u said but can't get it tight enough think I'll need the right tool thank all the same hope people under stand what I'm trying to do
Re: Need help again
I'm not sure what the connector looks like but another tool you could try is some circlip pliers. Google them if you don't know what they are and see if they might work with their little pins on the end.
Re: Need help again
Thanks Dx-Digger found 6-Inch 70-Degree Bent Long Nose Pliers might do the trick. I'll post a photo of the nut and try to find out the name of the tool. Thanks to all for the help
Re: Need help again
Think I've managed to get the photo upload
- sickboy
Re: Need help again
Embrace your inner muppet !
