Comtron 12 ,Mike and general question
original45
Call Sign: 45
Post by original45 » 01 Oct 2018, 19:03
Sunday I picked up a decent condition comtron12 " X11". I can't find any info on the net.
Unfortunately it didn't come with a microphone. So firstly I have a couple with the same plug types.
Will any of these suit , midland 100m. Colt 240, formac 120.
Anyone got a link to more info on it please too.
Thank you again
14CS06
Re: Comtron 12 ,Mike and general question
Post by 14CS06 » 01 Oct 2018, 19:25
Hello
Please insert a picture of your comtron12
original45
Call Sign: 45
Post by original45 » 01 Oct 2018, 19:43
Claude, I have taken images and tried to upload.
Unfortunantly it says file too big ?.
I am not good with I.t and dont have Dropbox or similar.
If someone would please be able to upload images for me could you private message me a email address or watsap number I would appreciate it so I may send you the images to upload here.
Thank you.
14CS06
Post by 14CS06 » 01 Oct 2018, 19:51
Hello
I use https://postimages.org/
Click to choose, copy & paste or drag & drop files anywhere
original45
Call Sign: 45
Post by original45 » 01 Oct 2018, 20:38
Hopefully image will upload now
14CS06
Post by 14CS06 » 01 Oct 2018, 20:45
Hello
similar
IRRADIO MC-700
Platine : 4010197
same PCB AS MIDLAND 2001 AM/FM 120 CH
original45
Call Sign: 45
Post by original45 » 01 Oct 2018, 21:18
Do you know if any of the mics for the midland 100m ,formac 120 or colt 210 woulld already be wired to suit so I may test radio further.
It may be a silly question but the dial that says -40+40+80 what is this for. Is this the selector to get the full 120 channels I imagine.
When it is switched on whilst on one of the positions activates the red light above channel selector. The other two positions don't illuminate it
Kind of confusing me a little.any advice info appreciated
ChrisMagpie
Call Sign: 26TM553
Post by ChrisMagpie » 02 Oct 2018, 02:40
original45 wrote:
01 Oct 2018, 21:18
The Midland 100m and Colt 210 mics will fit :)
-40 = low block
+40 = mid block
+80 = high block
Old school Maxon sounds so nice on AM :)
Clipper
Post by Clipper » 02 Oct 2018, 07:29
Same as the Colt 510; the red LED is just an indicator for low band (-40).
original45
Call Sign: 45
Post by original45 » 02 Oct 2018, 10:49
Oh that's fantastic, thank you all for the input.
Yes I didn't input that info apologies ,it does in fact illuminate on low.
Will let the switches dry as I have switch cleaned them all and try it out latter this evening.
Awesome.
The Collector
Post by The Collector » 02 Oct 2018, 19:02
The original Commtron/Maxcom mic's are prone to failing. I think I've had dozens over the years that've had no audio, no rx, no tx or have simply fallen apart as they seem brittle and fragile. I'm sure I've got one in my knackered-mic's box with a similar issue at the moment.
And as for the mic' plugs pulling out if you stretch the cable a bit too much...
The Collector
Post by The Collector » 02 Oct 2018, 19:08
That's sooo funny. This is on ebay at the mo, CXX version of yours (Nato) 27/81 uk channels on it, and guess what, no audio on the tx:
https://rover.ebay.com/rover/0/0/0?mpre ... 2801633479
original45
Call Sign: 45
Post by original45 » 02 Oct 2018, 20:19
Ah yes I spotted that one.
I never liked the 5pin din plugs back in the day . I did take the mic apart on the colt 210 as it was taped up. It wasn't broken just taped terribly but whilst it was apart I cleaned it insulated a wire and used some of that silicon rubber take around the black outer where it passes through the little metal grip lugs on the back to try help it not pull out.
I may cut a thin strip too and run it around the outer of the plastic jacket to the black outer cover on the wire .
Strangely enough I spotted on ebay some 5pin din type extend cables for about 3/4£
I am liking the older gear and I will try and join in on the Halloween am net coming up.
Seen a few mics from China ,same pin din for a £6 ,wired cobra I think but I can swap the wires easily enough.
grafter
Post by grafter » 03 Oct 2018, 22:08
I had one of these years ago along with a B300 and 7ft Firestik on the car and it was a great little rig. Had many good contacts on it including tons of Germans on FM lows and Middle East stations during F2 conditions.
original45
Call Sign: 45
Post by original45 » 06 Oct 2018, 09:58
I like it now I have been able switch it on due to no mic supplied.
Controls all function nicely and it sounds great on rx .
I believe it's on of those radios as 19 uk fm is on 73 that is off uk frequency
But it all seems to work v nicely.
I was shocked actually with no mic,two screws from casing missing and grubby but it's a little beauty .
Testament to the 70s 80 era of radio com and build I'm sure.
