PLL02A Replacement ?
1968neil
Post by 1968neil » 18 Sep 2018, 17:29
Hi Folks,
I have an old Superstar 2000 (blocks of 50)
The PLL02A has died and by the looks of it is not an easy to source chip nowadays ?
I remember vaguely that there are other chips that can be used as a substitute ?
Can anyone point me in the right direction please ?
Regards
Neil
recoil
Call Sign: 2e0myn
Re: PLL02A Replacement ?
Post by recoil » 18 Sep 2018, 18:46
I have a ss2000 and it has a Motorola 760136 pll in it which I think is same as a 02a .knights cb did have some 02a whether they have any now I don't know . or you could try e bay
Black Spirit
Post by Black Spirit » 18 Sep 2018, 18:54
If your stuck for an PLLO2A you can use an MC145106, Slightly different package but with some slight fettling still works perfectly well
1968neil
Post by 1968neil » 18 Sep 2018, 20:05
Thanks for the reply :)
Whats involved in using the MC145106 ? as i have a few of those in stock
Neil
KlondikeMike
Call Sign: 9WR2000
Post by KlondikeMike » 18 Sep 2018, 20:15
1968neil wrote:
18 Sep 2018, 17:29
... it is not an easy to source chip nowadays ?
And how much effort did your trying consist of? A simple Google search turns up multiple sources.
https://www.rfparts.com/integrated-circ ... ll02a.html
http://www.weisd.com/test/GenericParts_ ... d1=PLL-02A
etc..
9WR2000
cb4ever104
Post by cb4ever104 » 19 Sep 2018, 07:27
KlondikeMike wrote:
18 Sep 2018, 20:15
1968neil wrote:
18 Sep 2018, 17:29
etc..
The second one is an NTE equivalent . No point in buying from the States with postage etc. when you can buy an equivalent MC145106 locally for about a third of the price .
https://www.ebay.co.uk/itm/152761304508
1968neil
Post by 1968neil » 19 Sep 2018, 08:46
I agree with postage not a viable option,
As i said i have quite a few MC145105 ic's in stock.
I've had a look at the data sheet and looks like it's a simple enough swap with a few pin out differences.
Doing a UK google search turns up very little, obviously Canada has a better source ? ;)
Regards
Neil
The Collector
Post by The Collector » 19 Sep 2018, 16:32
Buy an early Binatone Route 66 uk radio and pinch it out of there. Later ones had different components iirc.
KlondikeMike
Call Sign: 9WR2000
Post by KlondikeMike » 19 Sep 2018, 16:39
OK, we'll blame Google for showing different search results between countries. Wonder what they see in China?
Myself, the drop in replacement is the way to go, whether new or pinched from some other dead system. Pay a little extra to do it right. I've used the NTE, works just fine. Hacking/cutting to make something else work would be a last resort effort.
9WR2000
1968neil
Post by 1968neil » 19 Sep 2018, 20:24
KlondikeMike wrote:
19 Sep 2018, 16:39
I agree with the hacking the radio about, not the way to go.
I have decided that making a custom PCB with the MC145106 is the way i'll go, So it simply just drops in the original PLL02A pcb footprint.
a much neater and repeatable solution.......
Regards
Neil
