HyGain V AFS (PTBM121D4X) RF/S-meter replacement option?
CrazyFin
Post by CrazyFin » 11 Aug 2018, 12:57
I have a HyGain V AFS (PTBM121D4X) where RF/S-meter has stopped working.
It is not stucked and meter moves when I knock on the plastic. I have measured the resistance of the coil and there is no resistance at all so most likely the coil is burned for some reason.
I have been trying to source a new (or used) meter but it seems quite difficult.
This meter has scale for S-level and RF power (up to 10W) and the only one I have found that miiiiight be an option is this:
https://www.avera.eu/trx-rx-spare-parts ... -0102.html
and this one
https://www.bellscb.com/products/access ... _Parts.htm (The "Cobra 25 Meter w/white light", 2nd from the top)
However, both of them has not really the same scale for RF power.
Any ideas as what I can use as a replacement meter or is there anyone of you who has a working one to sell me?
I guess for example the meter in the Tristar 747 is the same. Any other models you are aware of that has the same meter?
Meter measures about 30 mm wide and 15 mm high width a depth of approx 35 mm. Pictures here:
14CS06
Re: HyGain V AFS (PTBM121D4X) RF/S-meter replacement option?
Post by 14CS06 » 11 Aug 2018, 14:17
Hello
Please look at this link
Vu-mètre pour série MIDLAND/ ALAN,100M, 150M, 2001, 4001, 5001, 6001, 7001, etc.
Image Image
https://radio-media-system.com/epages/b ... cts/VUM001
Claude
Mitch
Post by Mitch » 11 Aug 2018, 15:57
I would think pretty much any cybernet radio meter would fit, the scale insert can be changed if done carefully so you'll still have the '10' FSD reading. They're only held together with sellotape, just put new tape on when re-assembling.
The perfect face for radio.
Black Spirit
Post by Black Spirit » 11 Aug 2018, 17:35
The meters in the links you posted wont fit they are larger meters too fit Uniden style radios, As above pretty much any Cybernet meter will fit York/Rotel etc but you wont have the 10 on the scale, To swap the decal depends on what meter you get as some did differ in design, The most popular was the one with a small "wheat bulb" that went into the side but some meters the bulb was on a bit of card that slotted from underneath these two meters the inlay is not easily interchangable.
Black Spirit
double post
CrazyFin
Post by CrazyFin » 11 Aug 2018, 23:37
Gents, thanks for all the good info. :thumbup:
@14CS06 / Claude: Wonderful link! I have now ordered two of those meters. Thanks! :clap:
@Black Spirit and @Mitch: Thanks for the tip of moving the scale. The model I have is the one with a small "wheat bulb" that went into the side so I should be able to swap the decal if I decide to go on that path.
Post by The Collector » 12 Aug 2018, 19:35
I've got a feeling a Concorde II meter would swap nicely, but can't recall what the TX power scale goes up to off the top of my head.
14CS06
Post by 14CS06 » 12 Aug 2018, 20:01
Hello
Concorde II meter is different
Claude
mrpsychopath
Call Sign: 108tm1313
Post by mrpsychopath » 13 Aug 2018, 08:26
Colt ssb, superstar 2000, tristar meters are same and go 10 watt scale
Post by The Collector » 13 Aug 2018, 11:39
14CS06 wrote:
12 Aug 2018, 20:01
Hello
Claude
Sorry Claude, I meant to say it's the same size but the readout plastic is different and I couldn't remember if it shows high enough on the wattage. It'd suit the radio nicely if the readout couldn't be swapped over for some reason.
CrazyFin
Post by CrazyFin » 04 Sep 2018, 15:08
Wohooo! Meter replacement arrived and it was a perfect fit!
Thanks for the tip Claude! :-)
