Internal speaker wires,what colour is posertive
original45
Call Sign: 45
Post by original45 » 23 Jun 2018, 15:31
Just wish to check the right wires , I marked them on removing but it's been apart before.
Green was connected pluss,yellow minus.
Is this correct before I mark them and 're connect please so speaker will work to its best.
Thank you
Call Sign: n0call
Re: Internal speaker wires,what colour is posertive
Post by ch25 » 23 Jun 2018, 16:29
Take DMM and check against ext speaker socket which one is -
astradyne
Moderator
Moderator
Post by astradyne » 25 Jun 2018, 08:14
It doesn't matter which wire goes where with CB radio internal speakers.
Look at the Cobra 148 GTL-DX for example. Both wires to the internal speaker are purple.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix » 25 Jun 2018, 08:43
Yup, makes no difference with speakers mate. :thumbup:
original45
Call Sign: 45
Post by original45 » 25 Jun 2018, 13:23
Thank you guys. Sorted. Ta muchly.
robber57
Post by robber57 » 30 Jun 2018, 17:49
MrWeetabix wrote:
25 Jun 2018, 08:43
Yup, makes no difference with single mono speakers mate. :thumbup:
It DOES make a difference with double or stereo speakers, just in case someone wants to hook up his stereo at home with knowledge he found here ;)
original45
Call Sign: 45
Post by original45 » 01 Jul 2018, 15:44
That's interesting as I would like to wire a set of headphones to give a stereo sound via both ear pieces.
Buick Mackane
Post by Buick Mackane » 01 Jul 2018, 16:01
If wired back to front current passes through the inductor the opposite way round which causes the magnetic field to be reversed, So the speaker cone sucks in when it should be pressing outwards and vice-versa
Although from a listeners point of view i dont think its noticable
paulears
Call Sign: G4RMT
Post by paulears » 01 Jul 2018, 19:23
With two or more loudspeakers, getting the polarity wrong on one of them does two things. First and the most obvious is that the bass content goes down, because as one speaker 'sucks' the other 'blows' and cancels out each other! It also wrecks the stereo effect - things only on the left stay on the left, things ion the rights stay on the right, but things that are right in the middle get reduced which sounds very odd.
if you wire headphones up you want the coils of each one to go in and out together on a mono source. If you get it wrong it does your head in. The sound appears to be in the middle of your head and makes some people feel sea sick! Easy do when each transducer has two conductors!
