Ham Major M588
listner132
Ham Major M588
Post by listner132 » 24 May 2018, 19:02
Hi guys i have above radio that i bought last year from Nic but i have just bought a watson wm-308 desk mic that i have been trying to wire up for the above radio...with no luck i may add. Has anyone got same mic that is wired up for the same radio that can post up the wiring code ? of can someone post up the wiring for me ?
would be very very happy...
thanks.
14CS06
Re: Ham Major M588
Post by 14CS06 » 24 May 2018, 19:12
Hello
Please look at this link for watson wm-308
http://www.g6vmr.co.uk/wp-content/uploa ... WM-308.pdf
cubwolf
Call Sign: M3CBY
Re: Ham Major M588
Post by cubwolf » 26 May 2018, 00:42
I think its the same as the Adonis in which case the audio is live without being on tx and there is also no rx wire.
In the 588 you will need a dual pole relay.
One pole to switch the tx and rx and the other to disconnect the audio from pin one on rx.
