Hi.. PLL measurements.
pin 17 - Low 0v / Mid 8.4v / High 0v
pin 9 - Low 0v / Mid 0v / High 0v
pin 2 - Low 820.053 KHz / Mid 1.27008 MHz / High 1.72011 MHz
Thanks!
Did you read the guys first post ?Kaliphan wrote: ↑01 Jun 2018, 15:19 I actually asked for pins 17 down to pin 9 but I wasn't very clear, sorry.
Something makes no sense here from what I am reading but let's try anyway.
if the VCO is locked the PLL should have a frequency on pin 2 that's 10KHz x the N-Code on pins 17 to 9.
0.82MHz says the N-Code should be 82
1.27MHz means 127 and you can probably work out the one for Hi?
That means the adders and PLL chip should be OK.
Can you check the PLL pis 17 to 9 are what I (and the service manual) predict? (8.4 is approximate)
Low Mid Hi
Pin 17 0 8.4 0
Pin 16 8.4 8.4 0
Pin 15 0 8.4 8.4
Pin 14 0 8.4 8.4
Pin 13 8.4 8.4 0
Pin 12 0 8.4 8.4
Pin 11 8.4 8.4 0
Pin 10 0 0 8.4
Pin 9 0 0 0
The Cobra works by mixing the VCO frequency with the 15MHz band crystal and feeding the difference frequency to the PLL on pin 2.
The PLL then divides that input signal by the N Code and compares it to a 10KHz signal thats been created by dividing the 10.240MHz signal by 1024, when they match the PLL is locked.
If they don't match, the PLL chip outputs pulses which are 'filtered' (integrated) to make an error voltage that drives the VCO up or down until they do match.
So, for CH1, Lo, the VCO should be 15.82MHz, Mid should be 16.27MHz and Hi 16.72MHz, please confirm that.
If the VCO is correct, please also confirm the voltages on 17 to 9 and VCO frequencies don't change on TX (pull out the bias board near the finals)
He's already got 16.490 on TP3 on CH19 MID band AM. So I doubt it's the PLL , VCO or Loop oscillator stage , as it's not "+10"ing there .
No Sammy.. ch19 mid is 16.5000 on TP-3 (it just won't go to 16.4900 unless I go to ch18)cb4ever104 wrote: ↑01 Jun 2018, 20:13 He's already got 16.490 on TP3 on CH19 MID band AM. So I doubt it's the PLL , VCO or Loop oscillator stage , as it's not "+10"ing there .
I read all the posts and watched as everyone got really confused which is why I went right back to basics so we've got a clear view of it all.cb4ever104 wrote: ↑01 Jun 2018, 20:13 He's already got 16.490 on TP3 on CH19 MID band AM. So I doubt it's the PLL , VCO or Loop oscillator stage , as it's not "+10"ing there .
currentstatus wrote: ↑01 Jun 2018, 21:54 No Sammy.. ch19 mid is 16.5000 on TP-3 (it just won't go to 16.4900 unless I go to ch18)
Sorry it's confusing testing and trying to align on ch19.. but the rig is actually on 27.195 (not 27.185). It's becoming more apparent now that the adders & PLL are probably OK.. and the fault is beyond that section. I've been speaking to Nick (great guy btw) and we've tested a couple of things but to no avail as yet.
I'll post those other measurements also tomorrow.
Yes the PLL is locked.. 16.5000 on ch19 (it should be 16.49000) so yes the whole rig is basically 10KHz off on all bands TX & RX.Kaliphan wrote: ↑02 Jun 2018, 08:56 So the VCO/PLL is locked, 16.5MHz is the right VCO frequency for 27.195MHz.
There are only two things I can think of that would cause it to be 10KHz up if it's locked.
Either your N-Code is wrong or the 15MHz is wrong.
Pin 9 (carry in) Pin 6 or Pin 7 on IC 6 changing would add 1 to the N code and cause exactly that problem, let's keep it on 19, check the voltages on IC6 pin 9 7 and 6 and also IC5 pin 17 on RX and TX please.
The 15MHz being 'off' by 10KHz would cause it too (and 10KHz off is a lot for a crystal so the KC slide would be reduced)
It's not impossible that something is changing on TX, either because it's been deliberately modded or because of a fault/half undone mod.
Did you check if it worked before you removed the EPROM board?
This is a clear indication the tuning coils for the 15.000 are tuned too high, The further down the slugs are the less coarse slide.currentstatus wrote: ↑01 Jun 2018, 12:29 Something I noticed.. the coarse clarifier is giving me +/- 3KHz .. in the spec it shows +/- 7KHz
It absolutely is and there's nothing else left to check now.Black Spirit wrote: ↑03 Jun 2018, 16:36This is a clear indication the tuning coils for the 15.000 are tuned too high, The further down the slugs are the less coarse slide.currentstatus wrote: ↑01 Jun 2018, 12:29 Something I noticed.. the coarse clarifier is giving me +/- 3KHz .. in the spec it shows +/- 7KHz
