Modifications within 360FM
radiogaga
Call Sign: 26TM399
Post by radiogaga » 18 May 2018, 16:05
I have these three modifications inside a 360FM (PB010AB).
At the SWR Board is this:
The Radio had the SWR Cal converted to variable power. I'm guessing the resistor was park of this hack.
Possibly connected, does this resistor usually sit on the SWR/CAL/SRF switch or is this too part of the same hack.
Also, what purpose is this diode ????
Sam
30TM399 Northern Costa Blanca
Call Sign: n0call
Re: Modifications within 360FM
Post by ch25 » 18 May 2018, 16:19
Black one? Seem to be between + and - so added as protection diode.
radiogaga
Call Sign: 26TM399
Post by radiogaga » 18 May 2018, 16:22
Sorry - Yes, didn't even notice the other one had sneaked into the picture. Can't see things for looking :)
radiogaga
Call Sign: 26TM399
Post by radiogaga » 23 May 2018, 13:33
radiogaga wrote:
18 May 2018, 16:05
[PICTURE1]
[PICTURE 2]
Sam
Anyone have an idea on the SWR board and SWR switch resisters, Pics 1 and 2 above?
Cheers
14CS06
Post by 14CS06 » 23 May 2018, 14:28
Hello
Same resistor on the SWR board on my Superstar 360FM
Claude
radiogaga
Call Sign: 26TM399
Post by radiogaga » 23 May 2018, 16:21
Thanks Claude - Is that he same on the SWR switch?
Sam
Call Sign: n0call
Post by ch25 » 23 May 2018, 16:25
When you modify swr cal to be power adjust, you have to add some resistance to preserve swr readings to be working.
When modified, you calibrate by adjusting power. Works fine, I've done it many times before in similar radios.
radiogaga
Call Sign: 26TM399
Post by radiogaga » 23 May 2018, 16:38
So are you saying the resistor on the SWR/Cal/RF switch is aftermarket or the resistor on the SWR Board as highlighted by Claude?
I don't see either on the schematic but neither appear aftermarket.
cb4ever104
Post by cb4ever104 » 24 May 2018, 11:06
radiogaga wrote:
23 May 2018, 16:38
The resistor on the RF/SWR switch is definitely aftermarket . As Chris already said , it was put there when the SWR CAL/Power mod was done on the radio . I don't have my radios handy , but the one on the SWR board at the back seems to be stock , according to Claude .
Sammy
radiogaga
Call Sign: 26TM399
Post by radiogaga » 24 May 2018, 11:18
Great Thanks...Not bad for a Benidrom Boot sale find
currentstatus
Post by currentstatus » 24 May 2018, 16:10
radiogaga wrote:
24 May 2018, 11:18
Haven't been there for a while.. get some interesting bits there sometimes :thumbup:
radiogaga
Call Sign: 26TM399
Post by radiogaga » 24 May 2018, 16:56
currentstatus wrote:
24 May 2018, 16:10
radiogaga wrote:
24 May 2018, 11:18
Bit further your way is Pedreguer (Just of the N332), on a Sunday. That's close to us. I've seen a few handies and AM radios there.
currentstatus
Post by currentstatus » 24 May 2018, 17:46
radiogaga wrote:
24 May 2018, 16:56
24 May 2018, 16:10
radiogaga wrote:
24 May 2018, 11:18
Yes that's a good one.. long walk around all the stalls.. takes a day to get around. I think it requires another visit this summer :)
cb4ever104
Post by cb4ever104 » 24 May 2018, 18:25
radiogaga wrote:
24 May 2018, 16:56
Yeah , I've done that one as well , although the last time was about 15 years ago :)
radiogaga
Call Sign: 26TM399
Post by radiogaga » 24 May 2018, 18:57
cb4ever104 wrote:
24 May 2018, 18:25
I'm willing to bet some of the crap will still be the same from 15 years ago!
Users browsing this forum: Google Adsense [Bot], original45 and 4 guests
