York 863 audio chip
NightProwler
Call Sign: 163TM186
York 863 audio chip
Post by NightProwler » 24 Apr 2018, 10:19
Hey all, Quick question about audio chips. I got a York 863 here and the volume is quiet, It has to be almost all the way up to hear anything and also there is no out going audio. Could this be the audio chip or do I need to look elsewhere?
Cheers everyone...Rich :thumbup:
The Collector
Re: York 863 audio chip
Post by The Collector » 24 Apr 2018, 11:10
It may be because of the mic' issue. When you haven't got a mic' plugged into a Cybernet-based radio, the audio is very very low. If the mic' is faulty it might not make a circuit that brings the audio alive? Try another cybernet-type mic' in it.
I'm no expert on mic's or radio internals though so I may be talking out of my bottom ;)
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 11:46
The mic is fine as I tried it on another York 863 I have, The internal speaker is also fine :think:
cb4ever104
Post by cb4ever104 » 24 Apr 2018, 12:11
What about an external speaker Rich . Still the same ?
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 12:58
Yep I tried that too
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 12:59
Do audio chips act like this when they go 'bad' or is it a case of they either work or they dont, If that makes sense?
Buick Mackane
Post by Buick Mackane » 24 Apr 2018, 13:17
Could be a faulty electrolytic capacitor in the audio chain
cb4ever104
Post by cb4ever104 » 24 Apr 2018, 13:43
NightProwler wrote:
24 Apr 2018, 12:59
Don't know . Never had a faulty one (yet :)) . You really need a scope so that you can do some measuring .
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 15:28
Buick Mackane wrote:
24 Apr 2018, 13:17
Thats what I was thinking old bean :)
sickboy
Post by sickboy » 24 Apr 2018, 17:33
Here's a handy page for your bookmarks
http://www.m0ysu.com/CybernetRepairsPage-2017.html
Especially this part:
Replace audio IC (TA7205) which also sometimes affects outgoing modulation too. NB. If you rub your finger across the back of the
Audio IC with the volume up and it makes a sound chances are the IC is fine and the fault lies elsewhere. If its completely dead its
more than likely the Audio IC.
Embrace your inner muppet !
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 18:36
sickboy wrote:
24 Apr 2018, 17:33
Ahhh Ive just tried that and it made no difference, I'll borrow an audio chip from another Cybernet radio and that should tell me. I dont really want to do that but at least I will know. Cheers Steve :thumbup:
cb4ever104
Post by cb4ever104 » 24 Apr 2018, 19:37
Put your tongue on the power connector terminals as well to see if the 12V is present 😀
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 20:21
I'll dangle my balls over the board instead :wtf:
cubwolf
Call Sign: M3CBY
Post by cubwolf » 24 Apr 2018, 20:52
Look at the caps just behind the audio chip.
C105 tends to fail.
Also while you are in there check C78 just in front of the 455 filter as almost everyone i have seen lately has started leaking.
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Apr 2018, 21:23
Just had a quick look and C102 appears to be leaking, The others look ok. I'll replace them and report back. Thanks for your help :thumbup:
Users browsing this forum: original45 and 7 guests
