NB/ANL SWITCH ON GALAXT SATURN ???
- WARLOCK
- Call Sign: 26TM134
On my galaxey saturn homebase when i turn the NB/ANL switch on the incoming signal gos up from 0-to 4 when on usb and lsb but not when on AM/FM is this normal , The Saturn is a early Dirland using a EPT360012B board if that helps apart from this it is a great radio far better than any modern radio i have tried , from George
Re: NB/ANL SWITCH ON GALAXT SATURN ???
Doesn't sound right . The NB/ANL should really only be noticeable on AM . Might work a bit on SSB . What you should notice is a decrease in noise on AM . It might affect the signal level slightly , but it definitely shouldn't increase the signal from S0 to S4 . Maybe it's been wired up for something else ?
- astradyne
Some kind of pre-amp mod?
I know there's a mod that can be done to the MK2 148's and 360FM's which produces the same results as you mention George. It's a long time since I've come across the mod I mentioned, but if memory serves it simply requires a 33pf ceramic cap across the back of one of the SSB tuning coils.
Perhaps someone can elaborate more?
Not me ! I've made a few boners recently . Most noticeably by inability to differentiate between a "Superstar 360" and a "Superstar 3600" . I'm going back to re-read The Big Dummys Guide .....
The amount of threads this guy has started kinda suggests he'd be better off trying another hobby,
- WARLOCK
Buick Mackane posts =6841 = 3.32 per day joined Aug 2012---Warlocks posts=1166 = 0.32 posts per day joined june 2008 , 6841 posts is a hell of a lot of posts in such a short time so will Buick Mackane be trying another hobby with me, I am sorry if i have broke the rules by asking too many questions i did not know there is a limit to how many questions one was allowed to ask maybe those in charge should let all of the members know what the limit is ,
from George---warlock
Yeah but 6000 of those posts are in the three word game george
- WARLOCK
No problem , so what will the new hobby be then ???
- WARLOCK
Thats enough fun and games it seems to work as a preamp on CW-AM-USB and LSB but not on FM any body got any thoughts on this mod to this radio or a cobra 148 as i have been told that this galaxy saturn is very much like a cobra 148 type radio
from George -- warlock???
Some pictures of the insides would go a long way . If not then we're just guessing . The main board is similar to the Cobra PB-010 , but with twin finals , bigger regulator , and a few other bits and pieces .
- WARLOCK
HI SAMMY, i guess it will remain a mystery as the radio has tags on it ,and anyway i would not know how to post photos and i do not own a camera or have a mobile phone that will take photos so as i said a mystery it will have to be.???
- Mudslinger
Maybe it has an eprom inside? Have you parked it next to another radio so that you can see if it stays on the same channel once the swich is switched?
The ANL is usually the first switch to be used for this purpose.
- astradyne
Surely if the switch moved the frequency/band of the radio that would show up on the inbuilt frequency counter?Mudslinger wrote: ↑11 Apr 2018, 19:53Maybe it has an eprom inside? Have you parked it next to another radio so that you can see if it stays on the same channel once the swich is switched?
I have seen some guys put a preamp in the radio and use the switches to go between the reg receive and the preamp. even other channels as the guys here have mentioned. you need to look close to see if any mods have been done to the radio
