MK1 Lincoln blowing fuses
NightProwler
Call Sign: 163TM186
Post by NightProwler » 23 Mar 2018, 21:29
Im gutted, After giving me many years of good service my MK1 Lincoln is playing up. Turned it on last night and as soon as you TX is blows the fuse, I havent had a good look inside but it smells a bit burnt :shock: Any ideas dudes?
Cheers...Rich :thumbup:
NightProwler
Call Sign: 163TM186
Re: MK1 Lincoln blowing fuses
Post by NightProwler » 23 Mar 2018, 21:42
Right just tried again and it went into TX ok but the output power slowly dropped down to zero and has lost all TX now. Could this be the output transistors gone? Why would it blow fuses though? :think:
Call Sign: n0call
Post by ch25 » 23 Mar 2018, 22:50
Possibly something went short, than burned to open circuit. I suggest to take RF probe and measure where power disappear.
Very common failure are faulty ceramic caps causing short to ground and MRF burn especially when run high power and bad SWR.
Tim
Call Sign: 26AT239
Post by Tim » 23 Mar 2018, 23:53
Bin it and replace it with something decent, never worth attempting to get it repaired.
NightProwler
Call Sign: 163TM186
Post by NightProwler » 23 Mar 2018, 23:54
Thanks Chris I will look into it. Tim...Grow up :roll:
cb4ever104
Post by cb4ever104 » 24 Mar 2018, 00:08
ch25 wrote:
23 Mar 2018, 22:50
What Chris said. Hopefully you won't have blown the final. Send it to Nick for a quick fix , and forget about Tim's comments. The Lincoln is still worth repairing.
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Mar 2018, 00:11
Thats what I will probably do Sammy. I cant understand how a radio that I have used for 5 years that has never ever let me down and always gets glowing reports from stations I have worked around the world is not 'decent' and fit for the bin {bnghd} This forum is just not what it used to be :cry:
Tim
Call Sign: 26AT239
Post by Tim » 24 Mar 2018, 08:55
Not what it used to be, neither it seems are peoples sense of humour!
timbob58
Call Sign: 26tm957
Post by timbob58 » 24 Mar 2018, 09:35
:lol: :lol:
Tim wrote:
24 Mar 2018, 08:55
cb4ever104
Post by cb4ever104 » 24 Mar 2018, 09:42
Tim wrote:
24 Mar 2018, 08:55
A smiley face speaks a 1000 words 😀
Buick Mackane
Post by Buick Mackane » 24 Mar 2018, 12:58
First port of call in fault finding is a visual inspection, Get the covers whipped off and look round the PA section for damaged capacitors etc
Tim
Call Sign: 26AT239
Post by Tim » 24 Mar 2018, 15:43
The smell could tell you a lot, that's if you haven't lost your sense of smell as well as sense of humour. :P
astradyne
Moderator
Moderator
Post by astradyne » 24 Mar 2018, 17:16
It might be worth taking a look at the torroid transformers. These are secured using that awful corrosive glue. While the larger higher gauge ones are generally fine, the smaller gauge ones can be damaged as the glue eats through the wire.
NightProwler
Call Sign: 163TM186
Post by NightProwler » 24 Mar 2018, 20:27
I do have a sense of humour Tim but when I come on a radio forum asking for advice about fixing a radio and get told to 'Bin it and replace it with something decent' I find that childish. It dont matter wether it's a Fideily 1000 or top of the range Yaesu. The point of this section of the forum to help other radio users fix their radio's. I give up I really do {bnghd}
Thanks to everyone else for the helpful advice, Except Tim :roll:
beamer320i
Post by beamer320i » 24 Mar 2018, 20:53
I'd much rather get a broken Lincoln repaired than own any of the 'new', modern radio's...
Serious question Tim, no trolling intended - What 'decent' radio would you replace the Lincoln with? (same value of course, no HF nonsense!) I only ask because I've always had one for the last 18 years and it would be only my only radio If I could only keep one. Build quality is excellent, simple to use, 26-30 with no gaps and very reliable if not abused. It may not be the most 'exciting' radio to use to some with it's lack of flashing fascia's, no echo but when it comes to working DX I can rely on it to make the trip where others have failed.
The only which comes a close second for me is the Ranger 2950DX in it's various guises, and that only gets second place because I find them slightly 'noisy' on RX, I tend to find them high on the white noise side. Again, that radio would NEVER win any beauty contests but it works!
As I'm typing this I've realised I haven't mentioned the Jackson (Mk.1 of course!) - Again, a superb radio which is equal to the Lincoln in my opinion (some will say better) on RX and TX, only loses to the Lincoln for me because it's on standard channel/block format but then again, that's not always a bad thing...Right, I've now started a Jackson vs Lincoln argument with myself so I'm off to sort this out! :D
