Spectrum communication piptone Roger bleep wiring?
Raverrst
Call Sign: 26LW29
Post by Raverrst » 22 Mar 2018, 09:50
Hi all..
Got a spectrum communications piptone bleep board, six wires, comes with fitting inductions but doesn’t tell me how to wire in a separate on/off switch so I can operate the radio with bleep on or off, what one of the wires is best to connect my switch to?
Thanks..
sickboy
Re: Spectrum communication piptone Roger bleep wiring?
Post by sickboy » 22 Mar 2018, 14:33
Usually the 12v, or the ground wire.
I did a modern President rig though with a board from Cubwolf and that had to be done with a 2 way switch on the PTT line. One switch position put the PTT through the board and the other switch position bypassed the board.
Embrace your inner muppet !
Buick Mackane
Post by Buick Mackane » 22 Mar 2018, 15:32
Raverrst wrote:
22 Mar 2018, 09:50
Hi all..
Thanks..
Email spectrum comms and ask :)
Raverrst
Call Sign: 26LW29
Post by Raverrst » 24 Mar 2018, 09:58
Thanks guys, yeah had messaged Spectrum but hadn't had a reply, however have now & yes is done through PTT line 👍
Raverrst
Call Sign: 26LW29
Post by Raverrst » 24 Mar 2018, 21:49
Right chaps... bleep board fitted all working 100%, fitted a on/off switch on the back panel all working as it should as per fitting instructions from spectrum. Half n hours use on ssb and it's suddenly stopped {bnghd} checked all my work can't find fault!? The rig is still txing and rxing without problem, I can hear the relay on the bleep board working just no bleep being transmitted! Any thoughts anyone as to whats up..
Buick Mackane
Post by Buick Mackane » 24 Mar 2018, 22:10
Is there a delay when you unkey ?
Raverrst
Call Sign: 26LW29
Post by Raverrst » 24 Mar 2018, 22:40
Yes slight delay when dekeying, flick back panel switch to off and no delay
Raverrst
Call Sign: 26LW29
Post by Raverrst » 06 Apr 2018, 22:42
All sorted, Board went back to spectrum, gate had gone down on the ic chip..
