Hi all..
Got a spectrum communications piptone bleep board, six wires, comes with fitting inductions but doesn’t tell me how to wire in a separate on/off switch so I can operate the radio with bleep on or off, what one of the wires is best to connect my switch to?
Thanks..
Spectrum communication piptone Roger bleep wiring?
- Raverrst
- Call Sign: 26LW29
Wednesday’s and Sunday’s 9pm 27.405 Usb, Qsk’s welcome
- sickboy
Re: Spectrum communication piptone Roger bleep wiring?
Usually the 12v, or the ground wire.
I did a modern President rig though with a board from Cubwolf and that had to be done with a 2 way switch on the PTT line. One switch position put the PTT through the board and the other switch position bypassed the board.
Embrace your inner muppet !
- Buick Mackane
Email spectrum comms and askRaverrst wrote: ↑22 Mar 2018, 09:50 Hi all..
Thanks..
- Raverrst
- Call Sign: 26LW29
Thanks guys, yeah had messaged Spectrum but hadn't had a reply, however have now & yes is done through PTT line
- Raverrst
- Call Sign: 26LW29
Right chaps... bleep board fitted all working 100%, fitted a on/off switch on the back panel all working as it should as per fitting instructions from spectrum. Half n hours use on ssb and it's suddenly stopped checked all my work can't find fault!? The rig is still txing and rxing without problem, I can hear the relay on the bleep board working just no bleep being transmitted! Any thoughts anyone as to whats up..
- Buick Mackane
Is there a delay when you unkey ?
- Raverrst
- Call Sign: 26LW29
Yes slight delay when dekeying, flick back panel switch to off and no delay
- Raverrst
- Call Sign: 26LW29
All sorted, Board went back to spectrum, gate had gone down on the ic chip..
