Hi Chaps
Bit of a long shot here. Does anyone have a schematic diagram for the above amplifier or know if it's circuity based on another amp. There seems to be very little information on the net that I can find for it.
Regards
Pete
RMS AL-100 Amplifier - Schematic
- Call Sign: Lemmy
Re: RMS AL-100 Amplifier - Schematic
What is the problem with that amp?
It is so simple, that you could draw it's schematic in less than 1 hour.
Hi Chris
The transformer is getting red hot and there are cuts on the trace on the main PCB as if someone has tried to mod it in some way, I'm not happy with the wiring on the PCB either, due to the above meddling. All I want to do is follow a diagram and put it back to its' original configuration if possible. I haven't tested the transformer yet for shorts which I will do shortly.
Regards
Pete
Regards
Pete
