Zetagi B300P Amp
pienari
Call Sign: 56la422
Re: Zetagi B300P Amp
Post by pienari » 04 Jan 2018, 11:04
In my base i allways run a bit higher voltage ab. 15 to 17v so i get more output same input.
My B300p in mobile runs quite hot at full output but it have worked 10 years without any problems.
Mobile. Harrier CB X, Megawatt 4000,Zetagi B300p.
Home. Colt Excalibur SSB , 2el Quad, Eurocb EA-150.
108EH002
Post by 108EH002 » 04 Jan 2018, 11:50
What power do you put into the mobile amp pienari ? cheers.
When running a 6 stage amp I always used a low pass filter connected straight onto the amp with a double 259 connector on the rx side,stops the reflective power.
You can talk worldwide on CB radio aswell,
rsgb are too far up their own @rses to admit it,
many freebanders just happen to know otherwise.
27.781.25 Fm
27.555 Usb
27.385 Lsb
27.315 Fm
27.275 Usb
27.025 Am
pienari
Call Sign: 56la422
Post by pienari » 04 Jan 2018, 12:50
Harrier push about 12w fm so i can get all out from B300p.
108EH002
Post by 108EH002 » 05 Jan 2018, 18:24
Ok pienari cheers,good swr on mobile antenna helps prolong the life of the amp.
27.781.25 Fm
27.555 Usb
27.385 Lsb
27.315 Fm
27.275 Usb
27.025 Am
Phoenix
Post by Phoenix » 03 Mar 2018, 21:16
108EH002 wrote:
04 Jan 2018, 11:50
Hi there is it possible to post a photo showing us your low pass filter connection Thankyou
26TM114
108EH002
Post by 108EH002 » 12 Mar 2018, 23:57
No,not possible as I dont have the same fitting now.Set up was Radio/3 ft patch lead/rmkl400/double 259 male fitting/zetagi 27 tvi filter/3 ft patch lead//power swr meter/rg 213 to antenna.
27.781.25 Fm
27.555 Usb
27.385 Lsb
27.315 Fm
27.275 Usb
27.025 Am
