Zetagi B300P Amp
pienari
Call Sign: 56la422
Re: Zetagi B300P Amp
Post by pienari » 04 Jan 2018, 11:04
In my base i allways run a bit higher voltage ab. 15 to 17v so i get more output same input.
My B300p in mobile runs quite hot at full output but it have worked 10 years without any problems.
Paljon pilalle tinailtuja koneita. ;)
Mobile. Harrier CB X, Megawatt 4000,Zetagi B300p.
Home. Colt Excalibur SSB , 2el Quad, Eurocb EA-150.
108EH002
Post by 108EH002 » 04 Jan 2018, 11:50
What power do you put into the mobile amp pienari ? cheers.
When running a 6 stage amp I always used a low pass filter connected straight onto the amp with a double 259 connector on the rx side,stops the reflective power.
You can talk worldwide on CB = not 10 - 15 miles,
Some are just too far up their own @rses to admit it,
Many freebanders happen to know otherwise = test free.
Its not how much = its how far :shh:
pienari
Call Sign: 56la422
Post by pienari » 04 Jan 2018, 12:50
Harrier push about 12w fm so i can get all out from B300p.
108EH002
Post by 108EH002 » 05 Jan 2018, 18:24
Ok pienari cheers,good swr on mobile antenna helps prolong the life of the amp.
Phoenix
Post by Phoenix » 03 Mar 2018, 21:16
108EH002 wrote:
04 Jan 2018, 11:50
Hi there is it possible to post a photo showing us your low pass filter connection Thankyou
26TM114
108EH002
Post by 108EH002 » 12 Mar 2018, 23:57
No,not possible as I dont have the same fitting now.Set up was Radio/3 ft patch lead/rmkl400/double 259 male fitting/zetagi 27 tvi filter/3 ft patch lead//power swr meter/rg 213 to antenna.
Users browsing this forum: Billy1965tipp, Google [Bot] and 4 guests
