ss3900 old style mid band/export switch wiring
mutley
Post by mutley » 09 Nov 2017, 18:06
Hi all,
While removing an old eprom's wiring I seem to have unsoldered one end of the switch that locks the rig to mid band.
The one end is still attached to the hi/low switch for the band selection A,B,C/D,E,F but not sure where the other end goes. It must be from somewhere near the sockets at the front, as that was where I was removing the wires for the coarse clarifier and a ground from the old eprom switching
I've tried to wok it out from a schematic, but i'm stuck... literally... on mid band.
Any info/advice greatly received :)
14CS06
Re: ss3900 old style mid band/export switch wiring
Post by 14CS06 » 09 Nov 2017, 18:26
Hello
Please look at this pics
mutley
Post by mutley » 09 Nov 2017, 19:21
Thanks for the photos Claude. I'm having a bit of difficulty following where the other end of the wire from the bottom of the hi/low band switch goes in your pictures though.
I'm fairly certain that my loose wire (It's red and comes from the toggle switch inside the case that locks the rig to mid) was connected to the solder side of the board at the front. You wouldn't happen to have any photos of that side would you?
I'm assuming it's just 8v or ground or something which goes into the band hi/low switch which is disconnected by the toggle switch when the rig was sold to lock it in mid?? I don't want to start randomly poking it around though in case I fry something.
speeddemon
Post by speeddemon » 09 Nov 2017, 19:27
Hi mutley. here mate look at this schematic :ugeek: cheers n 73's
14CS06
Post by 14CS06 » 09 Nov 2017, 19:49
Hello
mutley
Post by mutley » 09 Nov 2017, 21:04
Thanks guys, I'll take a closer look at all the info above tomorrow to try to work it out.
Seems there are so many slight variations of the same rig.. mine being the 3 way band rotary switch with high/low toggle, and the 40/240Ch (Mid/Export) switch has only 2 wires, one of which goes to the High/Low toggle switch and not the channel selector switch directly so will need to trace it all out.
I'll get there though :)
speeddemon
Post by speeddemon » 09 Nov 2017, 21:26
Hi mutley I hope you sort it all out. And get it fixed Gd luck mate cheers n 73's
mutley
Post by mutley » 09 Nov 2017, 22:58
Thanks mate.
Just had an epiphany and worked it out.
Thanks again to you guys for the photos and diagram
Cheers!
