Cobra 200 gt l no tx
tony2803
Call Sign: 163TM2803
Post by tony2803 »
Pick up a nice cobra 200 gtl with no tx. Everything else works fine. I can hear myself on talk back but no tx on normal transmit. Any ideas where to start.
speeddemon
Re: Cobra 200 gt l no tx
Post by speeddemon »
Hi tony2803 first id would check the rd16hhf1 driver its known to go bad and all caps n resistors/zeners /etc in predriver/driver/final stages and get yourself a service manual off the interwebbs .gd luck . Cheers n 73's
tony2803
Post by tony2803 »
Thanks for your reply
Looking at the circuit diagram I cannot find it. What would be the mosfet mark on the diagram . Thanks.
speeddemon
Hi tony2803. ya as far as I remember its trans mq73 left of L21 been awhile since I've had one on the work bench.. any needed info on it can be found on cbtricks .com and a quick google search cobra 200gtl dx problems might help you out .to get da known manufacturer bugz out of the radio . Gd luck cheers n 73's
sonoma
Post by sonoma »
Tony here is all the info from cbtricks that will help you locate the driver and how to tune the radio.
http://www.cbtricks.com/radios/cobra/20 ... /index.htm
sonoma
Post by sonoma »
you can go into the tour of the radio and click on the 3rd piture down and on the left to see the driver. it has 16hhf I think it is marked on top of the part you are looking for. I did not look in the service manual but it may have a voltage chart to check the part. most do have that info.
here is a link also from Cobras web site that might help if you do not find what you need on cbtricks. look at the service bulletins also.
http://downloads.cobra.com/10meter/10meter.htm
