Cobra 148gtldx advice ?
- gmham
- Call Sign: 108TM154
Re: Cobra 148gtldx advice ?
Perfect cheers for that appreciate your input. To be honest at the price I got it at it's worth a punt and a wee winter project !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
The resistor looks like a voltage dropper/ high low power, somebody removed jp3 to drop the supply to the driver & output transistors,
There's a K40 energising kit on the mic socket.
W8JI
- gmham
okay cheers , always interesting to see what's been added / butchered over the years on these things !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Mudslinger
A friend of mine has just dropped off a mk1 here.
Some of the bodges that people used to do to these things is shocking. There was a +10KC jumper mod which consisted of two wires being fed though a hole in the case. One of the wires had a 3.3K resistor on the end, so that when they were connected together it went up the +10Kc
I am pretty sure it will be a good radio once it has been sorted out.
It looks like someone has modded the Fine/Coarse control with a lump hammer.
I like stripping them down , removing all the crap , and rebuilding them from scratch . As long as there's no holes drilled , or tracks cut , then normally I don't mind too much .gmham wrote:okay cheers , always interesting to see what's been added / butchered over the years on these things !!!
- gmham
Yep probably best bet that way you know exactly what's what !! Should be with me tomorrow, will post more pics see if we can find all mods fitted!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
