Cobra 148gtldx advice ?
- gmham
- Call Sign: 108TM154
Guys been offered a cheap 148gtldx mk1. can any off you guys that know your way around the 148`s advise me if there are any apparant mods / repairs etc to the board from the following pics ?
http://i280.photobucket.com/albums/kk19 ... 1507379441
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: 108tm1313
- gmham
Re: Cobra 148gtldx advice ?
Yep will with nicks permission makes the trip down south !!! Just wondered if anyone could point out any noticeable mods / repaired by looking at the pic ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Buick Mackane
The link says Please update your account to enable third party hosting
- Mudslinger
I think the only mods you can really do to a Mk1 are a +10KC, bleep switch and possibly a UK40 eprom/pic
They don't expand very well.
- gmham
Okay cheers. will try this link : http://www.photobox.co.uk/album/5049314762
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
its had some mod or mods done but the pic is too low resolution to see what it may be.
the solder side of the board is what matters when you want to know if you bought a shitter, you can't hide pidgeonshit soldering & damaged traces.
W8JI
Definitely something been fitted to the side of it with the yellow wire . But can't see what it is .
- gmham
Okay cheers can email a much clearer picture over if anyone could host it for me ? unfortunately guess photobucket dont allow this now and the photobox link is very blurd ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Mudslinger
Have you tried Flikr for image hosting?
- gmham
No will do thanks
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Not sure if this image is any better ? if not will post pics off both sides off the board once radio arrives early next week.
https://www.flickr.com/photos/155760612 ... res/8DqBW5
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Mudslinger
It says page not found.
- gmham
Try that new link if you will -- sorry !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- andymuza
2 things I can see straight away that are not standard and both are linked.gmham wrote:Not sure if this image is any better ? if not will post pics off both sides off the board once radio arrives early next week.
On the first pic, bottom middle is a large white resistor. This has yellow and green wires going to it from near the back of the radio. You then have a blue and purple wires running from the resistor to a switch that is between the mic socket and the front of the radio. It appears that the switch is protruding from the screw hole. There appears to be two orange wires coming from the switch to the board just under the switch.
I have no idea what it is for as my knowledge of the MKI is limited but, those two items are not standard that is for certain.
It may be a power increase as if I remember correctly the green and yellow wires are running near to where the output power variable is. This would explain the use of this type of resistor and the reason it is mounted in the chassis in order to help dissipate the heat.
At the same time, I may be way off it may just be a switch to turn off or change the way the bleep sounds or give a + or - 10KC jump.
