What are the best trans.for a RM KL-203P AMP ???
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Having blown my RM KL203P amp can anyone put forward some better more powerful trans, ???
Mudslinger
Re: What are the best trans.for a RM KL-203P AMP ???
Post by Mudslinger »
Not sure about more powerful but knights did list the original RM3's.
I think you can use IRF520's as well.
speeddemon
Post by speeddemon »
Hi warlock use irf520's and don't overdrive them ie 5watts max am/fm Input to amp gd luck . Cheers n'73's
listner132
Post by listner132 »
I have changed the fets from the origonal rm3 fet i have tried both fqp13n10,s and also irf520's both replacments work ok but the power is about 30 watts less that what it was with its origonal fets..
The Collector
Post by The Collector »
I read something identical to this somewhere else just yesterday. Someone said they were probably poor, cheap replacements and someone else saying the bias needed tweaking to get better results whatever that is if it has one???
Try searching on this site to see if there's relevant info available.
dt307 may be the chap to contact as I think he's good with amp's ;)
dt307
Call Sign: 163dt307
Post by dt307 »
https://www.moonraker.eu/rm-mospower-rm3 not realy expensive less than a tenner to get the amp backup and running at correct power levels and the correct transistors.
fqp13n10 work fine but power is down to about 110w i fit theese because i have loads
https://www.mouser.co.uk/ProductDetail/ ... aoQAvD_BwE
or send me a pm and i post you 4 free .....not exactly gonna kill me or leave my self short
if5520n the "N" is for Never gonna sound good .....if you must use the irf520 non n
BTW save your self some pain if you dont have the skills/tools to remove the old ones correctly.
snip the old fets off at the body of the transistors and solder new ones directly to the legs of the old ones.
or if you must unsolder them same snip off the transistors at the body and unsolder 1 leg at a time and if there is any solder in the holes run a hand drill through them
https://www.amazon.co.uk/FOCCTS-Holding ... 0654&psc=1
163dt307-chris
― Albert Einstein
pienari
Call Sign: 56la422
Post by pienari »
I have tested several different fets and 48w IRF510 or IRF520 works. 520 less power then 510.
IRLZ14 and IRLZ24 works fine.
I have build diy fet amp 2drive 16fet @27v same fets and it work great.
Mobile. Ham concorde3, Megawatt 4000,Zetagi B550p.
Home. Colt Excalibur SSB , 2el Quad, Diy ldmos amp 1.6kw pep.
Unit 148 Mobile
Call Sign: G4ZOW
Post by Unit 148 Mobile »
Pienari,
Tell us more about both of your homebrew amp's the 16 fet unit and the 5kW one in your profile?
I have a US made 16 x Toshiba (originals) 2SC2879 mobile amp that runs luke warm at 1500W pep out and can easily run 2kW+ with a stiff 16V power supply.
Unit 148 - G4ZOW
pienari
Call Sign: 56la422
Post by pienari »
Yep its not 5kw,maybe i have to add 0 before ,5kw.
So that 2+16fet amp output is 500w dead key 10w drive and 1kw pep ssb @27.2v.
Boards are my own desing and build.
I got option to chance 2+20fet boards later.
I bought burned kl-503 and all fets was burned.
Maybe i mod this unit to 24v.
