Delta force bar signal meter
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 »
I have a Magnum Delta Force,now the signal meter works fine but the bar graph meter under the frequency doesn’t work on recive but is fine on transmit,any ideas?cheers
MARKASTERIX
Re: Delta force bar signal meter
Post by MARKASTERIX »
This must be a MK1 with the 1969 outputs. Normal its the MK2 with this feature. its just shows audio on TX.
M7LMH
Call Sign: M7LMH
Post by M7LMH »
It's fine thats how it work's. It's an audio meter nothing to do with receive
steepeljack69
Call Sign: 26SF333
It was working on recive when I first got the radio.
M7LMH
Call Sign: M7LMH
Post by M7LMH »
Strange as iv never seen it move on receive only transmit & iv owned a few & still run a delta force as my daily radio
astradyne
Moderator
Moderator
Post by astradyne »
There is a version where the LCD meter does move on TX and RX. I think it's the version that has a PA facility instead of CW.
On the Delta Force I own the LCD meter moves in TX mode only as a modulation meter.
dt307
Call Sign: 163dt307
Post by dt307 »
had a dragon delta force that did the same was working on rx and tx then the owner blew the radio,
i repaired or rather removed the mosfet and installed a 2166 but did trace the issue with the digital meter going awol but cant remember off hand what it was,if your still looking i will have a look at the schematic when i get time
163dt307-chris
― Albert Einstein
steepeljack69
Call Sign: 26SF333
Thanks for all your interest,I think it is as Astradyne says this version is Tx only,I must have seen something the bar graph on rx wasn’t working.Not t worry it’s a mint boxed radio so it’s ok as it is.Thanks again Mark
