Alinco dr135dx / astatic d104m6b
gmham
Post by gmham » 11 Aug 2017, 22:10
Guys Astatic d104m6b mic and the Alinco dr135dx anyone used this combination ? also anyone confirm the correct mic wiring for same ?
thanks.
.... Icom IC7300 / Cobra 148gtldx Mk2 / Kenwood TR751e 2mtr ssb... Ameritron ALS-600X SS HF Linear.... Cushcraft R6000 HF vertical / 80-10 mtr ocf dipole....... Astatic 575m6 mic / Heil ICM mic.
108-TM-154 - John
ROTEL240
Re: Alinco dr135dx / astatic d104m6b
Post by ROTEL240 » 12 Aug 2017, 08:22
A friend of mine used one on a alinco and it sounded very tinny, many use the KPO nm532 and they sound well.
gmham
Post by gmham » 12 Aug 2017, 08:28
Ok cheers, if anyone can confirm the wiring then that would be great.
108-TM-154 - John
dt307
Call Sign: 163dt307
Post by dt307 » 13 Aug 2017, 13:29
Pin 1 = Mic Audio.........white
Pin 2 = Not Used
Pin 3 = PTT....................Red
Pin 4 = Up/Down Not Used
Pin 5 = Ground..............Shield
Pin 6= +Volts STAY AWAY FROM THIS PIN !!!
163dt307-chris
― Albert Einstein
gmham
Post by gmham » 13 Aug 2017, 14:57
That's brilliant appreciatte that.
john
108-TM-154 - John
