Radio cuts out
2m0rdg
Call Sign: 2m0rdg
Radio cuts out
Post by 2m0rdg » 06 Aug 2017, 01:16
My friend has a superstar SS 6900n radio and the microphone keeps cutting out and DC comes up on the display , has anyone any ideas what the problem can be , rob
dt307
Call Sign: 163dt307
Re: Radio cuts out
Post by dt307 » 07 Aug 2017, 09:51
Problem with supply voltage
Psu under or over voltage
If that checks out ok make sure all connection are good inc fuse.
Can't remember if the under over voltage protection is user config in the menu/software if it is this also may be wrong
What psu is being used ?
163dt307-chris
― Albert Einstein
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Radio cuts out
Post by MrWeetabix » 07 Aug 2017, 10:19
Could be an under-powered PSU. If you're running a standard 3-5am PSU it may be struggling to supply on full power. Try running same radio on low power and see if the issues repeats. If not, then it's probably the power supply.
what is the radio rated as putting out on transmit?
Users browsing this forum: pienari and 2 guests
