Audioline 341 help
- superstar
Audioline 341 help
Picked up a cheap 341, was working fine for 10 minutes then went deaf, and no tx, there's squelch noise and channel display is working, hasn't been switched on in years up to now, whad ya rekon guys?
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- Call Sign: 26TM553
Re: Audioline 341 help
The two dodgy under rated 10v capacitors are the first things to be replaced.superstar wrote:Picked up a cheap 341, was working fine for 10 minutes then went deaf, and no tx, there's squelch noise and channel display is working, hasn't been switched on in years up to now, whad ya rekon guys?
https://www.youtube.com/watch?v=JedRaqYXEyk
- Mudslinger
I had a 345 homebase which had the same thing happen. I am afraid I am not sure what was wrong though, I sent it to Nick who worked his magic on it.
The problem with failing capacitors is that they often cause other components to fail as well.
- superstar
Yeah I've had similar faults on these where there's been no ch display no tx or rx and that was a couple of caps too, I'll see what nick says
Cb handle
Cb handle
- superstar
Above radio going on holiday to wales
Cb handle
Cb handle
- superstar
All done, above radio home and works ace!
Cb handle
Cb handle
Well worth the effortsuperstar wrote:All done, above radio home and works ace!
- jason
- Call Sign: 26TM070
What part was broken ?
- superstar
I can't remember what Nick said it was now but it wernt the 2 usual problematic caps
Cb handle
Cb handle
