CRT, bad quality control
LH27
Call Sign: TT
Post by LH27 » 08 Jan 2017, 19:54
Been out today helping a friend with his new CRT SS9900
The fuse in his powersupply blow off every time he tried to connect the powercable
Do you see why ?
CRT !!! This is bad quality control
(The radio was ok after switching the cable)
Lasse
ROTEL240
Re: CRT, bad quality control
Post by ROTEL240 » 08 Jan 2017, 20:02
Dont run the radio on full FM power or you will have another problem, the finals will blow...
stanogs68
Post by stanogs68 » 08 Jan 2017, 20:09
do you always need a fuse?
astradyne
Moderator
Moderator
Post by astradyne » 08 Jan 2017, 20:13
Must be two years I've had my 9900. Never had any issues with it.
On FM I run it at 10W max with an RM 400 if needed. It's been a great little radio with good reports.
There does seem to be quality control issues with most of the "new" radio's though, good and bad in each batch. So it's hit and miss as to what you'll get.
And yes, you should always use a fuse. You don't have to, but they are there for a reason.
14CS06
Post by 14CS06 » 08 Jan 2017, 20:18
Hello
Very good pic
Claude
ROTEL240
Post by ROTEL240 » 08 Jan 2017, 20:40
