I would like create this topic for all owners CRE 8900 / Alinco DR135DX.
In Poland one of CB service offer this modifications (translation from Polish)
1/ fine-tuning of the track receiver / transmitter
2/ installation of quartz filter and IF 10.695KNKTR - improving the selectivity / (Im not sure that I can buy
this filter - Borys)
3/ installation of an active filter IF II Channel Guard - to improve selectivity
4/ improving the tone of the narrowed down receiver - more treble
5/ improving modulation AM - louder broadcasting
6/ adding a treble in a transmission path - the more acute (louder?) modulation
7/ change the functions CLARIFIER in emissions USB / LSB - not muted reception when tuning
8/ Calibration indicator S / RF-METER
9/ Digital measurement system calibration SWR - more reliable measurement at higher transmission power
I wish to make this topic a know-how for anyone who want do this mods.
But, for now, I know only how to mod a CLARIFIER and tune RX/TX
It can happen that your radio is out of tune. This happens when the frequency on the display does not match the frequency of transmission or reception.
Set the example. 26.425.00 MHz and our respondents, who are also on this frequency can not hear us, and we hear them with great difficulty. Typically helped here knob clarifier, which tune the 'ear' to the frequency of our interlocutor. We had to set the example. 26.423.60 MHz to be heard at 26.425.00 MHz. So what to do to align the frequency display with real?
1. Press the "FUNC" button and holding it turn on the radio
2. Then press one after the other buttons RB, AN / ANL, DW
Radio came just in adjustment mode, and the display show the message SHOULD BFXXX (where XXX is the numeric designation of the setting, not the frequency). Using a dial channels and clarifier introduce the desired value.
If necessary, adjustment of the frequency shift should be performed separately for each modulation mode, rotating the selector dial modulation.
To save the new settings and exit the adjustment mode, turn off the radio.
After switching off the check results of our correction on the frequency meter or talking with someone about whom we know that he has properly tuning the radio. If necessary re-enter the adjustment mode.
Before you make any changes in the value of the parameters save them. Throughout this process, remember to CB radio was at room temperature, because it affects the correct tuning.
TIPS:
CW. Turn the CLARIFIER knob until frequency meter indicates 10.6950 MHz.
FM / AM. Turn the CLARIFIER knob until frequency meter indicates 10.6950 MHz.
USB. Turn the CLARIFIER knob until frequency meter indicates 10.6925 MHz.
LSB. Turn the CLARIFIER knob until frequency meter indicates 10.6975 MHz.
Note: when mistakenly introduced various parameters without storing them in advance is not possible to call them back using the RESET function. The RESET function does not change the parameters of the service menu.
Always save all the parameters of the radio before you change anything
2/ installation of quartz filter and IF 10.695KNKTR - improving the selectivity / (Im not sure that I can buy this filter - Borys)
This mod is not full described yet - if you know how do it, please tell us!
4/ improving the tone of the narrowed down receiver - /more treble
HOW DO IT?In my radio I used Hi-Cut button (which has been permanently disabled) to disable mute. Now I am enclosing Hi-Cut I can safely tweak and change channels.
Minus it is that at the moment does not work SQ, ASQ ie, the RX is always enabled. Just off the Hi-Cut and back to normal. Additionally, you can now attach a scan channels or DW, and at the same time be listening when changing channels in
Disconnect the collector of the control transistor Hi-Cut and connect it to the base of the transistor mute.
9/ digital measurement system calibration SWR - more reliable measurement at higher transmission power
Could you help with rest of mods? I'll edit first post if anyone post an instruction
