CRT SS 7900 Service Mode
fixitdaz
Call Sign: 26FB1104
Re: CRT SS 7900 Service Mode
Post by fixitdaz » 14 Sep 2017, 09:31
Do we have any more info on what,
4 FRQ
5 FRQ0F
6 BFO
7 AFR
8 CTSS
9 DCS
10 SUL36
11 SUL01
12 SFA36
13 SFR01
14 ASQ
15 RsiTx
stand for and is there any service info on the crt ss7900,Thanks
simonthewizard
Post by simonthewizard » 15 Sep 2017, 07:32
4 Frequency
5 Frequency Offset
6 Beat frequency Oscilator
7
8 & 9 It’s the adjustment of CTCSS board
10
11
12
13 Signal Frequency Recieve
14 Auto Squelch
15 This is the signal meter adjustment. (Also adjustable in programming software) Dealer
Every single radio has a different amount in the menu as all radios made different and not identical. Play here at your peril
Simon
fixitdaz
Call Sign: 26FB1104
Post by fixitdaz » 15 Sep 2017, 17:02
Thanks for the info Simon, do we know if there is a service manual for this radio when I got this radio it wasn't working correctly all the service menu had been altered and in am mode it would kill my power supply I turned am mod and this stopped it from tripping the power supply but there is still a problem in am mode as it transmits this is an eBay buy that I would like to get it going, I have put all service settings back to standard everything working except am mode and do we know what op3 is on underside of PCB same as op1 and op2 looks like you can link it for a third option, any info on a schematic or service manual would be greatly appreciated
Darren aka: fixitdaz
fixitdaz
Call Sign: 26FB1104
Post by fixitdaz » 11 Oct 2017, 18:56
My mistake its OP5 and it looks to be linked by a trace
ROTEL240
Post by ROTEL240 » 06 Nov 2017, 16:06
Anybody any wiser on how to use the service menu, i have a crt ss 9900 which seem slightly off frequency and was wondering if a slight ajustment would put the radio back on frequencyits the same menu as above ,ie to be spot on 27.3850 i have to be on 27.3851..not a big deal as i am using clarifier in tx rx mode (unlocked).Thanks fo reading....
listner132
Post by listner132 » 19 Sep 2018, 20:22
Old threat i know but just wondering if anyone has found out anymore about this service menu ?
thanks.
Nokia6233
Post by Nokia6233 » 03 Jan 2019, 00:07
Ich habe hier auch mal eine Frage zum Menü, im BFO Menü wird normal FM / LSB / USB eingestellt, zumindest in den Maas DX 5000 Geräten, wie sieht das hier z.b bei der CRT 9900 aus ?
Mir fehlen die Untermenü Punkte für die jeweilige Betriebsart im Service Menü !
Nokia6233
Post by Nokia6233 » 03 Jan 2019, 00:37
I have a question about the service menu
Normally it is so that you can set LSB and USB - FM BFO separately see (Maas DX5000) as this looks at the 9900?
4-5 and 6 .... What changes with menu item 4 exactly?
At menu point 5, the offset is set here for LSB and USB equally, I'm here as the separation of the individual operating modes from!
With menu item 6, I can do something but with 4 and 5 as missing more background information, this can anyone describe in more detail here how to sync LSB and USB in frequency separately.
