superstar 3600??
BaDBoY1985
Call Sign: 223TM085
superstar 3600??
Post by BaDBoY1985 » 31 Jan 2016, 16:39
any bodi know somthing abought this rig???? INTRESTING IT HAS ALINGNMET problems
RANGER 69FFB4 I SIRIO GPE 27
sorry for the writing i am HUNGARYAN :D
BaDBoY1985
Call Sign: 223TM085
Re: superstar 3600??
Post by BaDBoY1985 » 31 Jan 2016, 16:47
old or new version
Mudslinger
Post by Mudslinger » 31 Jan 2016, 17:05
They are very similar to the Superstar 3900's, only with less channels.
That one looks like it has a couple of add-on boards, possibly a UK40 Eprom and a bleep board?
What is the board number? It is usually near the front on the solder side.
14CS06
Post by 14CS06 » 31 Jan 2016, 17:26
Hello
The pcb is EPT360011Z
BaDBoY1985
Call Sign: 223TM085
Post by BaDBoY1985 » 31 Jan 2016, 18:19
claude i dont kow if its a new or old version of the 3600? and normaly how is the radio if it worcks 100%
cb4ever104
Post by cb4ever104 » 31 Jan 2016, 18:29
Mudslinger wrote:They are very similar to the Superstar 3900's, only with less channels.
Actually they're exactly like the 3900 . Just another clone . It'll either have a 6 way band switch (not all marked) , or 3 bands on either the HI and LOW tone switch .
Yours is TAIWAN , so it's old . As Claude says an EPT360011 pcb . The newer ones are all 14Bs ( I think) . I've sold a couple in the last year .
Dragonfly
Call Sign: 26TM363
Post by Dragonfly » 31 Jan 2016, 19:31
The later Superstars need 20 mins warm up to get on frequency then Alignment appears to be the same as the 3900 . http://www.cbtricks.com/pub/secret_cb/r ... erstar.htm
astradyne
Moderator
Moderator
Post by astradyne » 01 Feb 2016, 01:04
In the case of the 3900's the older the better. I'm not sure if the 3600 pre dates the 3900's slightly?
BaDBoY1985
Call Sign: 223TM085
Post by BaDBoY1985 » 01 Feb 2016, 02:55
thank you all for the quck replys were helpful
13EL121
Call Sign: 13DA121
Post by 13EL121 » 03 Mar 2018, 12:08
Superstar 3600 with SRT-3600-10 board. Don't know if it is old or new version. Looking for the correct value of xtal X2. See other post here in the 10/11m repair section...
cb4ever104
Post by cb4ever104 » 04 Mar 2018, 12:04
cb4ever104 wrote:
31 Jan 2016, 18:29
Apologies for what I said about these radios. Just shows what can happen when you don't know what you're talking about . The 3600 with the R.BEEP marked on the CH9 switch are 6 band 3900 clones , but these ones seem to be based on the single crystal EPT360011Z pcb which makes them a bit different. That's what I love about this hobby. Just when you've thought you've seen it all ....
14CS06
Post by 14CS06 » 04 Mar 2018, 13:43
Hello
SRT 3600-10 = EPT360010Z
cb4ever104
Post by cb4ever104 » 04 Mar 2018, 17:24
Yeah . I know that now Claude . Pity we don't have a proper schematic for the 10Z .
Just from what I've picked up over the last 24 hours . There's a sticker on the back of the Taiwan radios saying either "LO BAND" , or "HI BAND" . The LO BAND version is this "SRT 3600-10" pcb . I haven't seen the inside of the HI BAND one yet . It might be this same SRT 3600-10 pcb with both crystals fitted . Or it might be a later 6 band EPT board like the 13B , or similar . I'm going to add these 2 radios to my list .
14CS06
Post by 14CS06 » 04 Mar 2018, 17:58
Hello Sammy
The schematic for 5 BAND
cb4ever104
Post by cb4ever104 » 04 Mar 2018, 18:23
Hi Claude.
I think we've already had this conversion a few years ago when we discussed the Franklin. This diagram isn't correct. The diode matrix numbers are wrong. Anyway , it's not a major issue.
Thanks anyway.
