siskin wrote:iv tryed to post a few piocs but its impossable on an ipad i think iv got your face book details if im right ill send some internal picsbigpimp347 wrote:if thats a genuine stealth version i WANT IT..!!!!
thats one i don't have in my collection and been after a genuine one for years..!!
hi ive got 2 jumbos here how do you tell if its a stealth version
i'd even swap for a stock one that works fine..!!
oh 10kc out on every channel..
shouldn't be i'm sure i've seen this fault, but need to remember why..
the resistor getting hot, yup thats because they don't use a 5v regulator on the HAM marked Eprom.
thats just a period botch..
Ham international jumbo
- Call Sign: bigroy
Re: Ham international jumbo
- Call Sign: bigroy
- Call Sign: bigroy
hello 2who wants to fix my 2 jumbos for me any anybody
- Banned
- Call Sign: KA5PIU
Hello.
The Ham International "K" version is nothing more than a glorified 10 meter/CB radio that was produced for operation in Afghanistan and places like that, and they were supplied with this nifty suitcase it all went in.
A frequency counter was supplied, but there is NO difference!
Swan/Cubic did the same exact thing a few years ago.
https://forums.hamisland.net/showthread ... fca1c28eaf
So, why 27 MHz?
The idea was, and is, to provide a single band somewhat portable radio.
But, in Cuba, they hide full size satellite dish units inside water tanks!
They build radios, from scratch, and can build it into anything!
But, it was the Russians who were resourceful!
They built transverters into common radios.
You see, the Soviets were all about production, so radios were frequently sold new, that did not work!
You would have no choice but to have it repaired, your brand new radio!
Things like "Extended" FM band, for 88 to 108 MHz, were common.
A low power transmitter on the AM side was VERY common.
What they were used for? things like advertising black market goods.
This was the USSR of old, so a briefcase radio was nothing!
YOU could make a "spy" radio by simply mounting it inside something unexpected.
But, radios are now so small the point is moot.
Again, I saw the "k" model HRO radio a few years ago.
If that is the great spy radio, get a briefcase and put your radio in it, and you too have a "spy" radio!
Or, you can look at what the population in Cuba has been doing for years, not as spies, but want to watch US TV.
So, why 27 MHz?
- Call Sign: G0EHU
WTF is this guy on??
If you find out could you let us all knowG0EHU wrote:WTF is this guy on??
- cjay
- Call Sign: cjay
So we can all avoid it.cb4ever104 wrote:If you find out could you let us all knowG0EHU wrote:WTF is this guy on??
- Banned
- Call Sign: KA5PIU
Hello.
The HRI Jumbo has nothing special in the EPROM.
http://www.cbtricks.com/radios/ham_inte ... /index.htm
And, almost everyone has tried to glorify some cheezy radio by calling it the "Military model" or "Secret Agent" model.
This is nothing but marketing.
Handic, the large ORANGE walkie talkie, was being marketed as the "Emergency" radio.
http://books.google.com/books?id=yW-2Go ... io&f=false
So, it is not that I am on anything, I have just seen a lot of "Marketing".
And, I can supply you with the standard EPROM load (USA), but this radio does have an "Offset" board for the UK, if fitted, otherwise it is the same radio as the US model, power supply is 220.
Pull the cover, it is a mobile radio in a fancy box.
If the UK board is NOT fitted, they are available, nothing but a crystal and trimmer cap and PIN diode.
Selecting the correct band provides the signal needed, no added switch.
And, they are cheap, around $15 US.
The 10 kHz off, sounds like the V ref and N= need to be checked.
If N= is 1 and not 0 for the first channel, it will act as if it is 10 kHz high, but it is only that the channel is "up" by one.
You can insert any value between 0 and 16 for N=, 0 to F, it is hex.
The processor has a lookup table, by adding extra references, you get the 3 bands.
With an offset board, you can get the off UK frequencies.
With the N= function, you can "fill in" the "missing" channels, all of this has been known for years.
You now have, not only the service manual, with a detailed schematic, but an explanation of how a CB radio is "fitted" for the UK, or German, or whatever, channels.
We call it the "Euro" board in the USA.
This is different from the "Channel" board, that adds 2 "extra" bands, this radio already has that.
There is NO sense in installing a "5 band" board, this radio will NOT tune that far, it will fall out of lock.
Thank you.
Thank you.
- cjay
- Call Sign: cjay
'It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt.'Cowthief wrote:Hello.
Abraham Lincoln.
You, Sir, are a fool and have proven it.
- bigpimp347
clearly admin must think this idiot is worthy of being on this forum for some reason,
shame he's making the forum look like it's full of idiots and allows pillocks on..!!
as for the Jumbo..
they allegedly didn't do a stealth version, although i have seen/heard of a couple.
mk1 PTBM059 (multimode 2) twin board version.
mk2 PTBM121 (concorde 2) one single board.
mk3 PTBM133 (multimode 3) smaller single board more bands.
a lot of the UK versions (modded for 'legal use and stamped' were the mk2 which for me seems the hardest to find..!!
as for the Jumbo..
stood too close to his stepup tranformer once too often, but not close enough to shut him up.
W8JI
- cjay
- Call Sign: cjay
I could take that personally y'knowbigpimp347 wrote:clearly admin must think this idiot is worthy of being on this forum for some reason,
I'd never seen a non '059 Jumbo until recently, Marko Excaliburs yeah, but not the Jumbo and I've still not seen a '133 Jumbo in the flesh, I'd quite like one.bigpimp347 wrote: as for the Jumbo..
- Call Sign: RDX64
I used to have a jumbo and for the life of me cannot remember what I did with it.
The jumbo was (is) the most overrated UK CB of all time.
An under powered and noisy PSU, and just an MM2 or Concorde2 in a big box.
The best place for them is either pimps loft or landfill.
- bigpimp347
[quote="Admiral"
The best place for them is either pimps loft or landfill.[/quote]
