Strange McKinley issue
superstar
Post by superstar » 30 Oct 2013, 07:20
Here's an odd one for ya, I picked up a cheap but half tidy McKinley yesterday, it all works as it should tx/rx, but it also receives a broadcast station similar to talk sport :lol: in the background regardless of what channel you're on, it registers no signal and can be heard even with the volume down and the squelch up ( volume and squelch works normal for cb operation ). I've never come across this before, it look tidy inside too, what do you thinks up with it? :?
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
wa10
Re: Strange McKinley issue
Post by wa10 » 30 Oct 2013, 08:10
is it epromed?, i have had similar issue with a few eprom boards , one was in a McKiney, fingering the 5v reg on the eprom board stopped the music, changing the reg fixed it.
Mudslinger
Post by Mudslinger » 30 Oct 2013, 08:22
My Mckinley also did the same thing...
I found that running a wire from the Microphone socket to the metal part of my microphone sorted it.
Maybe a poor earth in the radio somewhere?
superstar
Post by superstar » 30 Oct 2013, 10:03
Hi, there's no eprom in there, all standard, I tried the mic wire thing but made no difference, the louder I have the volume up the more it drowns out the broadcast station, it's receiving 5 live :shock: , it a nice rig I'd love to fix this annoying fault, I've just turned down the volume to listen to the news :lol:
She's half tidy here's a pic :)
Cb handle
bigpimp347
Post by bigpimp347 » 30 Oct 2013, 10:17
you can do it on just about any radio :)
if you place your finger near the VCO area you will be able to receive AM broadcast ;)
and yes i can prove it before the know it all's start saying you can't, i have two videos, one on a Uniden 100 other is a Pama Danita mk5..
check around the VCO area for a bit of stray solder, damp, or some other short,
clean the board if needed, and check component side also, you might have a shorting out cap which is doing this..
superstar
Post by superstar » 30 Oct 2013, 12:40
Here's the solder side, I can't see anything but there again I ain't got a clue what I'm looking for :?
Cb handle
bigpimp347
Post by bigpimp347 » 30 Oct 2013, 13:51
check around the metal plate area, possibly remove it and see if the noise goes.
just check all the solder around there, make sure none has been changed/new and similar area component side too.
superstar
Post by superstar » 30 Oct 2013, 14:03
bigpimp347 wrote:check around the metal plate area, possibly remove it and see if the noise goes.
If I remove that plate my $h1t soldering iron will never allow me to put it back on neatly, what's that plate for anyway ?
Cb handle
Buick Mackane
Post by Buick Mackane » 30 Oct 2013, 15:18
superstar wrote: what's that plate for anyway ?
An RF shield
Real men DX on 20m using dipoles made of cheap speaker wire ;)
bigpimp347
Post by bigpimp347 » 30 Oct 2013, 16:23
yup usually an RF shield, but seeing as the radio has a lid another 4mm away and the RF is floating all around the radio i've never seen what they can do.. :)
you could have a bit of crap beneath it or even a dodgy joint,
are there any areas on the board you can touch where the heterodyned signal goes ??
you might even have a board to chassis cap gone bad
Clint
Call Sign: 26TM360
Post by Clint » 30 Oct 2013, 21:22
bigpimp347 wrote:yup usually an RF shield, but seeing as the radio has a lid another 4mm away and the RF is floating all around the radio i've never seen what they can do.. :)
Its not the same, the lids are tied to the chassis and not to the ground rail, the chassis and ground should be capacitively decoupled from each other..
26-TM-360
Old 80's Radios and lots of them - Vintage Computers especially late 70's C=PETS :)
Clint
Call Sign: 26TM360
Post by Clint » 30 Oct 2013, 21:24
bigpimp347 wrote:cap which is doing this..
My first guess - or a harmonic being produced from one of the oscillators vco or xtal.
26-TM-360
superstar
Post by superstar » 31 Oct 2013, 10:18
Here's a vid of it in action :?
http://youtu.be/oeIUL3VmtnQ
Cb handle
NUBSTER
Call Sign: 26TM545
Post by NUBSTER » 31 Oct 2013, 12:18
This might sound a silly question as I am not up on technical stuff inside of a radio, but dose it do this if you took the radio say mobile or to another place (QTH), just wondering if its actully somthing within your home thats causing it
Buick Mackane
Post by Buick Mackane » 31 Oct 2013, 12:34
Im not at all familiar with this radio. But looking at your pic of the solder side of the radio i dont see any caps between the chassis & ground :roll:
I wonder if the problem could be the audio amp itself
