Noise Squelch in Cybernet 134
- wheel bender
Re: Noise Squelch in Cybernet 134
A very informative and well composed post there Ugs. The binatone 5 star isn't just a good radio it's the best looking of the 134's and tends to look better for longer than the others too. I got into Europe with mine on mid block last year and really enjoyed the experience. That squelch mod is very tempting for going mobile with. As the biggest problem with cb for the non cber is the hash crackle and pop!
Wheel Bender 1982-88/ 2007- ???
27+ countries since 2007
keeping the older radios on air. Not in the cupboard or the past.
80ch legal- America on ukfm- CB radio can be better 2nd time around.
- Ashtec
- Call Sign: M6LTD
The best mod ive found to work after playing about with these radios is put a 16v 10uf cap across the emitter & collector of Q14 this sort's the popping and banging sound out on these radio's ive found............
[CENTER]
[/CENTER]
The Noise Squelch dose work well but they don't take to well to CB'ers over deviating.
This mod also work's well on the Ham International Puma but put the 16v 10uf cap across the emitter & collector of Q12
[CENTER]
[/CENTER]
- Mudslinger
Looks like an easy modification Paul.
Although if I am honest the Cybernet squelch pop doesn't really bother me.
- Ashtec
- Call Sign: M6LTD
- Ashtec
- Call Sign: M6LTD
- Mudslinger
I might try it on my Harrier CB once it is fixed just to see what happens.
What I would be more interested in though is a mod which would make the TX audio sound more like a Uniden.
Loud, clear and full of depth rather than someone speaking with a peg on their nose and a sock in their mouth
- Ashtec
- Call Sign: M6LTD
Adjust RV6 to 9 o'clock looking from the front of the radio will sort that for you............Mudslinger wrote:I might try it on my Harrier CB once it is fixed just to see what happens.
- Mudslinger
Ashtec wrote:Adjust RV6 to 9 o'clock looking from the front of the radio will sort that for you............Mudslinger wrote:I might try it on my Harrier CB once it is fixed just to see what happens.
Cheers Paul, is that the one which stands upright?
I will try it on the Harrier CB before doing it to the CBX, as the CBX still has the original factory seals.
- Ashtec
- Call Sign: M6LTD
Yep it is..............Mudslinger wrote:Ashtec wrote:Adjust RV6 to 9 o'clock looking from the front of the radio will sort that for you............Mudslinger wrote:I might try it on my Harrier CB once it is fixed just to see what happens.
- Ashtec
- Call Sign: M6LTD
Any one tried the PTBM134 squelch mod
- Mudslinger
Is that the one where you disconnect a wire, disconnect one end of a resistor and solder it to the wire?
I tried it on my old Rotel but I didn't like it.
Instead of having a point where the noise dissapears, the noise gets quieter the further around you turn the squelch. Like a volume control in reverse if you like.
- Ashtec
- Call Sign: M6LTD
No that's a crap mod if ive ever seen one................Mudslinger wrote:Is that the one where you disconnect a wire, disconnect one end of a resistor and solder it to the wire?
- Mudslinger
Ahh I see. Not tried that one.
- RadioPixie
- Call Sign: 26TM552
Yes Mr Ash I have! I couldn't find a 16uF but I tried a 10uF and was happy with the performance. Tried a 22uF and the squelch was slightly delayed before opening - no good!
So now waiting for the soldering to heat and in goes the 10uF. Cheers for the idea *thumbs up*
P.S. It's the Barracuda HP940. Next mod will be to araldite a 6pin mic connector to be wired "President standard" to the front panel. Mods so far: Mid band of course, "HT" 2nd IF filter, DIM reduces brightness of both the LED and the meter, and Ch19 instead of Ch9 with extra diodes to display "19".
- RadioPixie
This is a different mod Muddy, and much, much, much better than that mod you are referring to
