Noise Squelch in Cybernet 134
- Ashtec
- Call Sign: M6LTD
Re: Noise Squelch in Cybernet 134
A post Mitch posted up some time ago..
Lafayette 1800 (125 board) some weeks ago and while it doesn't kill the pop altogether it certainly makes it a lot less and it's very easy to do. It slows down the switching a bit but enough to improve it. Just solder a 1uF electrolytic between the base and collector of Q27, on a 125/131 board (Q25 on a 133), and you'd be surprised how much better it can be, not perfect but simple and works. I did experiment a little and found the 1uF was about right but you can have a play too.
- Ashtec
- Call Sign: M6LTD
Now that looks like something I could find on the board.
I've got more chance of understanding an A-Z map of the Sahara Desert than I have of understanding a radio board's schematic
Thanks Paul!
Thanks Paul!
- New User
- Call Sign: Rotel
hello
lol very late to the party
very new or re new to CBs (after 40 years )
come straight to the point ...do i understand correctly that i just solder the capacitor to the legs of q14 (york 863)
ps soz to be that person
- Call Sign: 26TM773
Remove the front leg of R60 (10k) from the board (RHS front of PCB). Solder a wire into this hole (connects to Q14 collector) and solder the other end to the post near the front of the board which has a blue wire (usually blue) going to the volume control.
If you want to make it switchable, wire the free leg of the resistor through a switch.
- New User
- Call Sign: Rotel
tried that one didn't like at all just lowers the volume in a strange way.
was referring to adding the 10 uF cap to Q14 seemed to get positive feedback .
OK, yes, just solder a 16v 10uf cap across the emitter & collector of Q14
- New User
- Call Sign: Rotel
Thanks for confirming have a good day
- New User
- Call Sign: Rotel
Fantastic
- Vapor
- Call Sign: dipstick
soldering a 16v 10uf cap across the emitter & collector of Q14 transforms the squelch behaviour, no more poping or rumble as squelch breaks. this was the one annoying thing with cybernet based radio's. but no more. have done this to all mine and so much better.
A great MOD for all cybernet based radio's.
CB dipstick
73's and Good DX people!
