President Madison channel change 'pop'
- bluegrass69
- Call Sign: 26tm430
Can anyone tell me if there is a simple way to suppress the 'pop' sound every time I change channels on a Madison. It didn't bother me when I first got the radio but I'm getting a bit fed up with hearing it now. I seem to remember a mention of this on a thread a while back but I haven't been able to find it again. Is it just a case of disabling or removing a transistor which hopefully doesn't affect anything else ?
Richard
26-tm-430
26-CT-930
26-tm-430
26-CT-930
- Clint
- Call Sign: 26TM360
Re: President Madison channel change 'pop'
In the old book of tricks its snip R225
26-TM-360
Old 80's Radios and lots of them - Vintage Computers especially late 70's C=PETS
- Clint
I would like to caveat: I am not sure if there is any detrimental effects
26-TM-360
- NightProwler
- Call Sign: 163TM186
'snip'.....BOOM!!!
- Clint
NightProwler wrote:'snip'.....BOOM!!!
26-TM-360
- 163TM847
Oddly enough i did a search for that same info earlier today and couldn't find it either, I am sure it was Ashtec [Paul] who mentioned it And i did it too a Cobra 140 i had here at the time cos the "chuff chuff" each time I changed channel really got on my Moobs, Anyway it did work with no ill effect that i noticed.
I am in the process of getting an old Zachery T i salvaged from a scrap bin up and running, Its all working now and i have fitted an Spectrum FM board and i am getting that slight "chuff" when changing channels which is no real big deal but i would like rid if any one knows.
PC-407AC Board
PC-407AC Board
Build a man a fire, he'll be warm for a night. Set a man on fire and he'll be warm for the rest of his life.
- bluegrass69
Thanks Faffer, that's the one I was looking for.
Richard
26-tm-430
26-CT-930
26-tm-430
26-CT-930
- wheel bender
I love the 'doof doof doof' as I flick through the channels on the madison we have here. I wouldn't change it for the world.......but I also prefer the push button bleep on the delta force turned on and hygain peewit bleeps.....I never claimed to be sane.
Wheel Bender 1982-88/ 2007- ???
27+ countries since 2007
keeping the older radios on air. Not in the cupboard or the past.
80ch legal- America on ukfm- CB radio can be better 2nd time around.
- Crusader
Hi guys,just dug up this old thread to ask... is there a similar mod to stop the popping noise on the Stalker XV (15) base set??.
R198 on the XV looks to be the equivalent of R225 on the Madison , so I'd remove it and see what happens .
Or...you could just cough every time you change channel.
Not very helpful am I
- Crusader
Cheers Sammy,will give that a try soon & let you know if it works,cheers for your inputcb4ever104 wrote: ↑02 Mar 2018, 09:35 R198 on the XV looks to be the equivalent of R225 on the Madison , so I'd remove it and see what happens .
- Crusader
Just to let you know Sammy i found R198 it is a 100K & is at the top right hand side of the PCB near the back & is sat right next to TR45, i unsoldered one end of the resistor & there is total silence when turning the channel selector so it works a treat!!
Again.. Thank You so much for your help on that one.
Regards,Shaun
Regards,Shaun
